Yesterday I transferred an old Motion Sensor I to a Motion Sensor II using the Replace function in the Insteon Plug-In.
Everything seemed to be fine until today, after updating HS3 to version 3.0.0.478. After re-starting HomeSeer, I got the following in my startup log:
10/5/2018 3:10:36 PM ~!~Insteon~!~Error loading Device 93 from insteon.ini file. It has a duplicate Insteon Address 4D.CA.D9 which is already registered to Device 64
10/5/2018 3:10:36 PM ~!~Insteon~!~Warning! The following device already exists in the Device List: 4D.CA.D9
That is the new motion sensor. Device 64 is the old one.
This happened before, should I follow the instructions you gave at that time? I'll find it in here somewhere....something about deleting the newer item, but then I will be left with the old motion sensor in the database?
