Please backup your config\insteon.ini and data\homeseer.hsd files.
New Device support:
- Motion Sensor II
- Siren Module (2868) support; this device superceeds the Alert Module
- EZsnsRF basic support (you must link manually the device to the Interface)
Changes:
- Added sorting feature to Device Manage page. Click column heading once for asc sort, click again for desc sort. Currently, your sort option will not persist between plugin restarts.
- Revised dimmer sliders to include max value 100. This will allow setting 100% On via the slider regardless of default on-level. See Note 1 below.
- Disables polling for devices that do not respond after 2 failed attempts. See Note #2 below to disable this feature.
- Revised Insteon Receive message format to include HS Location2
- Added some additional Configuration Change Trigger calls
- Manages the insteon.ini file internally; does not use the HS3 methods. See Note #3 below
- Revised ini management routines. The insteon.ini will be re-saved about 3 seconds after any required changes (comm stats, polling results, or config changes)
- Device value set to -1 (Unknown) if polling fails
- Changed the default value for the Hub setting GetXMLBufferInterval=2000
- Syncing linked responder devices now use the responder link values to set the on level and ramp rate
- Hub.GetBuffer routine won't generate report log files on exceptions; now logs a Normal msg
- Added 'Disable Relay Polling" option to IOLincs. Use this option if polling is triggering the relay
- The Interface Port help text on the Config page will now display the list of available ports
- Added an Insteon tab on the hs devices edit pages that includes links to the plugin
- Allows empty or blank group locations to better support Alexa
- Small improvement to Hub II buffer processing
- Revised logging for Hub network errors; no functional changes
- Added additional message processing for new Hub messages
- Revised Hidden Door Sensor support; added 2 Groups option - see user's manual
Fixes:
- An error (can't write to log file) associated with External Device registration.
- A bug when display sub device on add/Create Group page
- An error when using All Off button with Controlinc
- Registration of old motion sensors (fw 30 or older)
- IOLinc polling fix
- Resolved X10 control issue
- Revised KPL HS Devices sync with KPL LEDs
- Revised KPL HS Devices sync when using radio or combine button groups
- A bug when programming a group without a controller
- A bug with original motion sensors causing exceptions
- X10 polling for dimmers supporting preset dim
- Config folder name change for Linux
- KPL HS device syncing
- On-level and ramp rates in group definition for KPL Load device #9
- X10 processing will ignore X10 messages for devices owned by other plugins
- Fanlinc/Keypadlinc control from HS dev management page
- KPL and switchlinc syncing
- Device syncing will not propagate the Beep command
- Unknown group broadcasts will not generate an exception/error report; just logged
- Increased field space on Insteon ID fields
- Linux dimmer image reference
- Hub issue with older UK Hub 1 (devicetype 0330) processing
Please post any issues with this beta to this thread.
Notes:
1. You will need to either manually change the slider definition by changing the max value from 99 to 100 or add RecreateDevices=1 to the [config] section of the insteon.ini and restart the plugin. Do not use the ini option if you have customized your devices.
2. add FailedPollThreshold=0 to the [config] section of the insteon.ini to continue to poll devices that do not respond. The default value is 2.
3. I have incorporated my own ini file management routines in an effort to avoid losing the insteon.ini file when HS3 crashes or terminates unexpectedly. The ini file will get reordered/sorted by section and key when its saved but nothing should get lost. use the Configuration trigger and Backup Configuration action to make backups.
New Device support:
- Motion Sensor II
Changes:
Fixes:
Notes:
