Recover Config
This topic is closed.
    Recover Config
    I lost all my Insteon HS3 configuration. We had a power failure and my HS3 stopped working. I first noticed that the "Interface Port" was blank. I then entered the correct interface port, but then all the devices disappeared In the past restoring the Config and Data directories would resolve this issue (I thought). But I've tried recovering from several back up sets and it keeps doing the same thing...blank interface port, config, loose all devices. What is the secret recipe?
    if you restore a good copy of then config/insteon.ini, data\homeseer.hsd, and maybe config/settings.ini (this identifies the hsd file to use) you should get your setup back.
    please verify the contents of the insteon.ini before you start the plugin, and verify the hs insteon devices exist on the dev mgmt page before you start the plugin
    Mark
    HS3 Pro 4.2.19.5
      btw, what hs3 version and plugin ver were you running when the power failed
      Mark
      HS3 Pro 4.2.19.5
        How's the recovery coming along?
        Mark
        HS3 Pro 4.2.19.5
