HS3 Insteon Plug-In Version 3.0.7.36 BETA (Windows & Linux)
This is a sticky topic.
    #31
    Mark's Betas are VERY reliable in my experience. They always fix problems, and never break things so I always update to the latest Beta as soon as it is available. I've never been burned. He always updates the release notes so I know exactly what has changed in each Beta version. Huge kudos to Mark for his responsiveness, programming skills and attention to detail. Wish I could say that about all the software I use...
      #32
      I have many Insteon 2477Ds and HS Zee troller. What controller should I use with Insteon as my x10 Cm15a isn't the most reliable?
        #33
        how many x10 and insteon devices to you actually have? insteon traffic can cause x10 performance to degrade. so changing controllers/plugins may not help
        that said, the insteon PLM and Hub both support x10 as well. I would recommend the PLM first.
        Mark
        HS3 Pro 4.2.19.5
          #34
          posted 3.0.7.27. change to the hub comm; trying to eliminate the getresponsecallback errors
          Mark
          HS3 Pro 4.2.19.5
            #35
            I can't update to 3.0.7.27...log states 404 error file not found?
              #36
              i have an email into HST. not sure what's going on
              Mark
              HS3 Pro 4.2.19.5
                #37
                Any Hub users tried the latest beta? anything to report? I'm looking for feedback on a on reliable connection between the plugin and the hub.
                Mark
                HS3 Pro 4.2.19.5
                  #38
                  I am using 3.0.7.5, which I think you may have sent me directly due to an issue with an old hub. I'm loath to change unless I can be sure whatever caused the previous problem is resolved. in the new available version.
                    #39
                    what was the issue?
                    Mark
                    HS3 Pro 4.2.19.5
                      #40
                      Originally posted by mnsandler View Post
                      what was the issue?
                      I can't remember! I have the old 'larger' hub. You did an update and then something stopped working.
                        #41
                        would you mind testing this latest beta. i was working with another user who has the larger hub, and i think we made some improvements. you can always rollback. just save the current hspi_insteon.exe and bin\insteon\insteon.dll files before upgrading.
                        i added some additional detailed logging
                        Mark
                        HS3 Pro 4.2.19.5
                          #42
                          OK. I'll let you know.
                          Done. OK at the moment.
                            #43
                            anything to report?
                            Mark
                            HS3 Pro 4.2.19.5
                              #44
                              anything to report?
                              At the moment, all seems OK.
                                #45
                                I posted 3.0.7.36. Anyone having issues with the hub should give it a try.
                                Mark
                                HS3 Pro 4.2.19.5
