Already starting the next beta cycle...As always, make backups of your entire HS3 setup
Changes
- A hub error on the UK Hub I with device type 0330 (3.0.7.1)
- Added Detach Load feature to On/Off KPLs (device type 022C) with fw 43+ (3.0.7.2)
- Added "Sync attributes with hs devices" to KPLs. Disable to allow custom name, location, and location2 values on KPL hs devices (3.0.7.3)
- Added Advanced Settings tab within plugin. These settings are documented, but were previously only adjustable by editing the insteon.ini. Do not change unless we discuss your particular issue/need. (3.0.7.4)
- Added an Advanced Setting to enable the HS Set Device Value trigger that fires when the value is set to the existing value (eg Off to Off) (3.0.7.4)
- Added 'Poll All Devices' action (3.0.7.4)
- Revised 'Poll All Devices' action to include an interval delay (3.0.7.5)
- Added a Cancel button to other programming transactions (3.0.7.6)
- No longer removes hs devices if the insteon.ini file is lost/deleted/removed (3.0.7.6)
- Saves the insteon.ini to a new "Insteon Plugin" device. This will help with restores (3.0.7.6)
- Added Off Processing for MS II when in Occupancy Mode II (3.0.7.8)
- Added IOLinc 070D (3.0.7.11)
- Added 2 scene mode to the remotelinc2 switch (3.0.7.15)
- Added LED on/off for Range Extenders (3.0.7.16)
- Added European hidden door and motion sensor device types (3.0.7.17)
- Added Up/down to open/close module (3.0.7.26)
- Changed Pause on open/close module (3.0.7.27)
- Revised Hub http protocol (3.0.7.27)
- Reverted Hub http Protocol (3.0.7.30)
- Changed LightsOnRampRate action for fw 43 (3.0.7.30)
- Revised Hub http protocol (3.0.7.33)
- Revised Hub http protocol (3.0.7.36)
Fixes
- Moved supporting DLLs to the bin\insteon folder using hspi_insteon.exe.config file (3.0.7.5)
The installer should create a bin\insteon subfolder and put insteon.dll and ftd2xx_net.dll in there also, you should get an hspi_insteon.exe.config in the hs root
- Action configurations settings lost, now restored(3.0.7.7)
- Reset and Reprogram Interface button (3.0.7.9)
- Outletlinc lower outlet Unknown status (3.0.7.9)
- Beep and Poll action (3.0.7.10)
- MS II registration process (3.0.7.11)
- supports more that 256 insteon devices (3.0.7.13)
- linux serial port issue during power failure (3.0.7.13)
- KPL sync error when KPL is offline (3.0.7.15)
- lamplinc sync issue (3.0.7.18)
- Update X10 Devices routine for devices created from another X10 plugin (3.0.7.19)
- Hidden door sensor LED options (3.0.7.21)
- Log received error (3.0.7.23)
- KPL detached Load device management (3.0.7.25)
Changes
Fixes
