have any of you hub users tried the latest beta .36 and have anything to report?
HS3 Insteon Plug-In Version 3.0.7.36 BETA (Windows & Linux)
This is a sticky topic.
Mark
HS3 Pro 4.2.19.5
Originally posted by JoelWener View PostI have installed .36 and will be testing it. The insteon plugin in HS4 has been not stable for a while. Within 4-6 hours of the plugin being started, it seems to stop working, always giving the operation has timed out errors in the log.Mark
HS3 Pro 4.2.19.5
HS3 Pro 4.2.19.5
there is a beta section in the Updater. you can install from there.Mark
HS3 Pro 4.2.19.5
you should be able to install and start the plugin. However, as you suggested, the plugin won't do anything until it can communicate with the PLMMark
HS3 Pro 4.2.19.5
the Updater is a hs feature on the hs Plugin pageMark
HS3 Pro 4.2.19.5
Originally posted by Lenp2001 View PostI got the plug in to work fine and have been adding devices but I don't see any place to do any beta upgrade or "beta section in the updater" if that's some menu I don't know where to find or navigate to. Thanks
Click the yellow arrow next to Additional Interfaces
Scroll down to the bottom
Second to last is Beta
(You probably figured this out by now, but just in case....)
Jim Speiser
38-year veteran of Home Automation
Still don't know squat
Hey Mark,
Regarding beta 3.0.7.36, running HS4 on Windows 10, Hub R3.6 1820. Ever since I installed the beta, I have been getting "Interface_TrapError called from SendHex" messages. This occurred daily for about 2 weeks, for different devices at various times.
I reverted back to 3.0.7.1 and, for the last 4 days, no Sendhex.
I don't mind going back to the 3.0.7.36 beta if you tell me what you need in terms of info. But seeing you are close to releasing the HS4 beta, it might be more effective to try that version instead.
What do you think?
