I added a HomeSeer + PLM (2413U) to a system with about 100 insteon devices and currently controlled by an ISY994 + PLM (2413S).
Every device added without difficulty to the Insteon (mnsandler) module, with the exception of two (of two) 2487S keypad relays (v.44 & v.41).
I disabled the Insteon (mnsandler) module, and enabled the HSInsteon module. I am able to add the 2487S devices to the HSInsteon module without difficulty. Switch back to mnsandler module and the devices aren't recognized. This leads me to believe the problem is in the mnsandler module.
Log message
The Insteon device at XX.XX.XX did not respond. Please check to make sure the address is correct and that the device is powered-up. The device was not registered.
Both devices function normally in the existing system, and the ISY communicates with the devices normally.
I tried changing the location of the PLM, including plugging into the outlet controlled by a 2487S relay, but I'm unable to register the device with the mnsandler module.
HS3 Pro Edition 3.0.0.484 (beta) on a HomeTrollerSELv2, Insteon (mnsandler) 3.0.7.1
Log message
