Hi I am finally re-setting up Homeseer on a laptop. I have been able to get all my Insteon lighting and fan controls working fine with your Plug-in. I have not had any luck with the Morninglinc lock controllers. I saw that the Plug-in supports the Morninglinc Lock Controller. I have tried them in both the On and Off states. They will not register. I had them working on my old setup but I was using a USB Insteon Controller. I noticed on this forum that the supported PLMs are very specific and the Portable controller is not listed. Is there anything I should try? Or have I been very lucky with all the Insteon devices I have got working.
Morninglinc controller & Portable USB adapter 2448A7
you need to either manually link the morninglinc to the interface or via the plugin tap-add function. see the usb adapter manual for the manual procedure.
you cannot register the lock via the regular plugin process.Mark
HS3 Pro 4.2.19.5
Glad you got it working.Mark
HS3 Pro 4.2.19.5
