Hi I have HS3/Rpi with the 2413U USB interface and an Insteon Hub running in parallel on the network. I duplicate critical events to avoid coming home to a dark house if one of them crashes. My goal is to have all events only running on the HS3/Rpi once I can depend on it. I just got an Alexa to control the HS3/Rpi.
I am intermittently (mostly) getting long delays when I send commands from the HS3/Rpi to turn on or off lights and devices from the Devices screen. HS Mobile app or Alexa. When I control them from the Insteon Hub App there is no delay.
I am assuming this list below is probably generating extra traffic and wasting cycles. I've tried 'Update Interface Database' and 'Reset and Reprogram Interface' in the plugin with no change. The devices below are added to both the Hub and the Rpi and appear to work although the on/off statuses are not always accurate.
What is the best way to resolve this?
Brian
You have 31 internal Insteon device(s) registered in the system, 0 external device(s), and 0 group(s).
These devices and groups currently consume 73 link database entries in your interface.*
You have 254 unused outbound link addresses out of 254 total available.
* Click the Display Interface Links button below to update this number.
The following are unregistered Insteon addresses found in the network.
0C.CB.29 found in Backyard Spots Behind Garage
0F.E0.D9 found in Backyard Spots Behind Garage
45.5D.F7 found in Backyard Spots Behind Garage
0F.E0.D9 found in Backyard Spots BSMNT Slidering
45.5D.F7 found in Backyard Spots BSMNT Slidering
0F.E0.D9 found in Backyard Spots MBRM
45.5D.F7 found in Backyard Spots MBRM
2A.DC.38 found in Backyard Tree and Bug Lights
31.2D.B2 found in Backyard Tree and Bug Lights
45.5D.F7 found in Backyard Tree and Bug Lights
0F.E0.D9 found in Basement Water Heater
31.2D.B2 found in Basement Water Heater
45.5D.F7 found in Basement Water Heater
0C.CB.29 found in Deck Over head light Slave at back door
0F.E0.D9 found in Deck Over head light Slave at back door
45.5D.F7 found in Deck Over head light Slave at back door
0F.E0.D9 found in Deck Spotlights at Kitchen door
2A.DC.38 found in Deck Spotlights at Kitchen door
31.2D.B2 found in Deck Spotlights at Kitchen door
45.5D.F7 found in Deck Spotlights at Kitchen door
0A.1F.DC found in Diningroom Lamp
0B.4B.85 found in Diningroom Lamp
0F.E0.D9 found in Diningroom Lamp
12.C4.D4 found in Diningroom Lamp
12.ED.E0 found in Diningroom Lamp
2A.DC.38 found in Diningroom Lamp
31.2D.B2 found in Diningroom Lamp
45.5D.F7 found in Diningroom Lamp
45.5D.F7 found in Driveway Audi Remote
16.EF.8C found in Garage Bay 1&2 lights
45.5D.F7 found in Garage Bay 1&2 lights
45.5D.F7 found in Garage Bay 3&4 Lights
45.5D.F7 found in Garage Garage Door 1
45.5D.F7 found in Garage Garage Door 2
45.5D.F7 found in Garage Garage Door 3
45.5D.F7 found in Garage Lights Over Doors
0F.C3.9A found in House Driveway PIR
0F.E0.D9 found in House Driveway PIR
31.2D.B2 found in House Driveway PIR
45.5D.F7 found in House Repeater
45.5D.F7 found in House simple home net
45.5D.F7 found in Kitchen Counter Lights
0F.E0.D9 found in Kitchen Glass Cabinet
45.5D.F7 found in Kitchen Glass Cabinet
0F.E0.D9 found in Kitchen Overhead Light
2A.DC.38 found in Kitchen Overhead Light
31.2D.B2 found in Kitchen Overhead Light
45.5D.F7 found in Kitchen Overhead Light
0F.E0.D9 found in Kitchen Sink Light
2A.DC.38 found in Kitchen Sink Light
31.2D.B2 found in Kitchen Sink Light
45.5D.F7 found in Kitchen Sink Light
FF.FF.FF found in Kitchen Sink Light
0F.E0.D9 found in Main Bathroom Light
2A.DC.38 found in Main Bathroom Light
31.2D.B2 found in Main Bathroom Light
3D.2D.B2 found in Main Bathroom Light
45.5D.F7 found in Main Bathroom Light
0A.23.65 found in Master Bedroom Master Bedroom ceiling Fan
0F.E0.D9 found in Master Bedroom Master Bedroom ceiling Fan
2A.DC.38 found in Master Bedroom Master Bedroom ceiling Fan
45.5D.F7 found in Master Bedroom Master Bedroom ceiling Fan
53.2D.B2 found in Master Bedroom Master Bedroom ceiling Fan
0F.E0.D9 found in Outside Front Flood Lights
2A.DC.38 found in Outside Front Flood Lights
31.2D.B2 found in Outside Front Flood Lights
45.5D.F7 found in Outside Front Flood Lights
0C.C6.E9 found in Outside Front Front Porch
0F.E0.D9 found in Outside Front Front Porch
12.E1.CD found in Outside Front Front Porch
2A.DC.38 found in Outside Front Front Porch
31.2D.B2 found in Outside Front Front Porch
45.5D.F7 found in Outside Front Front Porch
0F.E0.D9 found in RecRoom Lamp
31.2D.B2 found in RecRoom Lamp
45.5D.F7 found in RecRoom Lamp
45.5D.F7 found in RecRoom Overhead Lights
The following devices have duplicate links:
Deck Spotlights at Kitchen door (10,12)
Outside Front Front Porch (1,12)
Brian
