I have several Motion Sensor IIs controlling lights in various places in my house. While they all work well, in some places I need to have the timeout set to something greater than the default (say, 5 minutes) due to the nature of the room and the sensor location.
However, this also means that if we leave the room and turn the light of manually when we leave, it will not turn back on automatically until the timeout on the Motion Sensor II has elapsed. As I understand it, the Motion Sensor II is a controller only, not a responder so there's no way to send a command back to the motion sensor to tell it to reset its timeout. Is that correct?
With the recent updates to the plug-in to fully support Occupancy II mode (i.e., the "off" on a different group), it seems to me that I'll need to keep the motion sensor's timeout low, have it turn on the light and also start a timer for the duration that I want the light to be on. The timer will then turn the light off when it runs out. If I turn the light off manually, I can send a command to stop and reset the timer. And since the sensor's timeout will be set low, it should turn the light back on if someone comes back into the room shortly after turning the light off manually.
Does my logic make sense, or is there an easier way to accomplish this?
Steve
Steve
