PLM failure?
  • PLM failure?
    Mark,
    I am getting "Transmit failed to device (various) after 4 tries" messages, about a dozen or so a day. I went back in the log and saw they started August 10. No added equipment, etc has been added during that time. No other changes that I can think of. I did a ' a reset and reprogram on the interface' today but that didn't help. the PLM is firmware 9E, h/w ver 2.0.
    The unit is about 3-4 years old, I think. I'm thinking its time for a new one?
    the problem could also be some device flooding the network and preventing the PLM from transmitting. you could try turning off breakers one at a time and see if the issue stops. this would help identify where the noise is coming from. for light switches, you can pull the set btn to disable it.
    Mark
    HS3 Pro 3.0.0.534
      ok, I'll try that first, thanks, and I suppose it could also be rf devices?
        Yes, an RF device could be the cause. don't rule anything out
        Mark
        HS3 Pro 3.0.0.534
          one last question: is there anything I can do from the plm to speed up the process of elimination, such as initiate polling on all devices?
            yah, that might work. give it a try
            Mark
            HS3 Pro 3.0.0.534
