Minimum hardware to use Insteon with HS3
    Guys,
    I've got a new customer who is insistent on going with Insteon. What is the minimum hardware/software to start with Insteon? Would the 2413U or 2413S/Insteon plugin/HS3/hardware be all that is needed to get started?
    -Rupp
    Yep. The PLM is so critical that I keep a spare on hand. My primary is almost 15 years old but still working fine. Be sure and get dual band devices if you have a choice.
      Dual Insteon devices are listed nicely as those with two checkmarks @ https://www.insteon.com/support-know...nsteon-devices
        Unless buying old/used equipment I think the IOLinc is the only NONE dual-band Insteon device left. Everything else is dual-band which makes it a non issue anymore.
          Regarding dual band, I'm probably sensitive to it since I have several older switches without it. I also use battery powered devices (motion, door/window, minimote) so the dual band really is important. In one area of the house I had to replace an older but working switch with a newer one to get better coverage.
            I'd be interested in hearing just WHY your customer insists on Insteon for a new install. I probably would, too, but only because I don't know enough about Zigbee, etc. What has s/he heard about Insteon?
            Jim Speiser
            Still don't know squat
              Jim, His son uses Insteon and has a lot of good things to say so Dad is going with it or at least partially with it.
              -Rupp
                What does dual band do for you. Does it bridge the phases of the house. Is there any other equipment needed for dual band to work?
                -Rupp
                  Dual band uses both the powerline and wireless.
                    For me, the dual mode allows the closest battery powered device a good way to get to the PLM.
                    When I first got into insteon, it was customary to get 2 range extenders (which were dual band) and put one on each phase to bridge them. As I've added more dual mode devices, I no longer use the range extenders.
                      Rupp
                      Menards has been dumping all their Insteon stock. Right now you can purchase an Insteon hub Model 2245-222 for $49.00. It lists for about $79.00. They also have some starter kits for $99.00, which is $100.00 off list price.
                        Originally posted by drhtmal View Post
                        Rupp
                        I looked online and there were no PLM's. I wonder if the PLM is old stock and would that matter? We do not have Menards in this area but thanks for the heads up.
                        -Rupp
                          Stores dumping can be a good sign with new product lines gearing up for release, but I think in this case Menards is just clearing space.
                          Rupp would one of these work for you? https://www.smarthome.com/insteon-24...b-adapter.html or is the Insteon 2245-222 Hub a necessity? Same site sells a refurb PLM for $60, but then it might be smarter to contact a friend/family that lives close to a Menards where a new one is $49.
                            You can use the 2245-222 Hub in place of the PLM. I have the 2245-222 Hub for my few Insteon devices. It was on sale at Menards so I thought I would try it. Seems to be working well. Menards can ship it to your home. I am using Mark Sandler's plugin.
