Hi,
Ive got 2 of the 2450 IO Lincs that report not supported.
Both are Rev 2.0a - 1202
I have some other IO Lincs that work OK, different Rev/Dates...
Thanks, Joe
Logs show:
Sep-08 10:26:11 PM Insteon The Device Type is not supported. Check the HS Log for additional information.
Sep-08 10:26:11 PM Insteon Scheduled polling resumed.
Sep-08 10:26:11 PM Insteon Note: This message will be eliminated once the device type is added to the plugin.
Sep-08 10:26:11 PM Insteon Please post this new device type in the forum so it can be permanently added to the plugin.
Sep-08 10:26:11 PM Insteon An unknown Insteon device of type 070D was found.
Sep-08 10:26:11 PM Insteon Received a Broadcast message from 1C.06.3C: 01 1C 06 3C 07 0D 41 87 01 00
Sep-08 10:26:11 PM Insteon Got controller/responder type broadcast for Insteon ID 1C.06.3C of type 070D, Firmware version 41
Sep-08 10:26:11 PM Insteon Received STX 0x50 (Raw Insteon Rec):1C 06 3C 07 0D 41 87 01 00 Debouncing repeat.
Sep-08 10:26:11 PM Insteon Sending http://192.168.0.224:25105/1?XB=M=1
Sep-08 10:26:11 PM Insteon ..My XML buffer: 02501C063C070D4187010002501C063C070D41870100
Sep-08 10:26:09 PM Insteon Received a Direct ACK from 1C.06.3C: 1C 06 3C 33 C2 BA 2B 10 00
Sep-08 10:26:09 PM Insteon Received STX 0x50 (Raw Insteon Rec):1C 06 3C 33 C2 BA 2B 10 00
Sep-08 10:26:09 PM Insteon ..Got Hub Response 02 62 1C 06 3C 0F 10 00 06
Sep-08 10:26:09 PM Insteon Sending http://192.168.0.224:25105/1?XB=M=1
Sep-08 10:26:09 PM Insteon ..My XML buffer: 02621C063C0F10000602501C063C33C2BA2B1000
Sep-08 10:26:08 PM Insteon Sending http://192.168.1.224:25105/3?02621C063C0F1000=I=3
Sep-08 10:26:08 PM Insteon Sending command 02 62 1C 06 3C 0F 10 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Sep-08 10:26:08 PM Insteon Sending Insteon ID Broadcast for '1C.06.3C'
Sep-08 10:26:07 PM Insteon ..Got Hub Response 02 6F 41 A2 01 1C 06 3C 00 00 00 15
Sep-08 10:26:07 PM Insteon Sending http://192.168.0.224:25105/1?XB=M=1
Sep-08 10:26:07 PM Insteon ..My XML buffer: 026F41A2011C063C00000015
Sep-08 10:26:06 PM Insteon Sending http://192.168.0.224:25105/3?026F41A2011C063C000000=I=3
Sep-08 10:26:06 PM Insteon Sending command 02 6F 41 A2 01 1C 06 3C 00 00 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:True
Sep-08 10:26:06 PM Insteon Calling AddRecord for 1C.06.3C 1 True
Sep-08 10:26:06 PM Insteon Scheduled polling temporarily stopped.
Sep-08 10:26:06 PM Insteon Attempting to add Device 1C.06.3C
Thanks, Joe
Logs show:
