Insteon no longer able to communicate with Hub
This topic is closed.
    Hi, I've been running HS3 with the plug-in for a few years. I recently bought a new one as the older unit failed. I was able to get it up and running pretty quickly. Shortly after, I recently migrated HS to a new Host, and have been unable to get it to connect ever since. I get the message ** Unable to communicate with the Insteon powerline interface *** and the plug-in itself is giving me the "check the interface..." message. I am able to connect to the HUBs port via a browser, even from the new Host. The log doesn't seem to be telling me much, as just seeing...
    --------*Initialization Log*--------------
    10/17/2019 7:58:15 AM - Host System: 192.168.1.15 (vMS1) 3.0.0.548
    10/17/2019 7:58:15 AM - Plugin HSPI_Insteon.exe version: 3.0.7.1
    10/17/2019 7:58:15 AM - Insteon Support library (Insteon.dll) version: 1.0.7.1
    10/17/2019 7:58:15 AM - RegisterCallback Completed
    10/17/2019 7:58:15 AM - Enter InitIO
    10/17/2019 7:58:15 AM - Enter InitPlugin
    10/17/2019 7:58:15 AM - Global initialization of plug-in required, starting up.
    10/17/2019 7:58:15 AM - In ProcessRawReceiveThread
    10/17/2019 7:58:15 AM - Initializing Insteon hardware interface...
    10/17/2019 7:58:15 AM - Initializing Interface...
    10/17/2019 7:58:15 AM - In PLMBuffer_ProcessBufferThread
    10/17/2019 7:58:15 AM - Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    10/17/2019 7:58:15 AM - Sending http://192.168.1.35:25105/1?XB=M=1
    10/17/2019 7:58:15 AM - Sending http://192.168.1.35:25105/3?0260=I=3
    10/17/2019 7:58:18 AM - ..did not receive a response from the Interface
    10/17/2019 7:58:18 AM - ..Retry #1 required. Pausing 250ms for Interface to clear...
    10/17/2019 7:58:19 AM - Sending http://192.168.1.35:25105/3?0260=I=3
    10/17/2019 7:58:22 AM - ..did not receive a response from the Interface
    10/17/2019 7:58:22 AM - ..Retry #2 required. Pausing 300ms for Interface to clear...
    10/17/2019 7:58:22 AM - Sending http://192.168.1.35:25105/3?0260=I=3
    10/17/2019 7:58:25 AM - ..did not receive a response from the Interface
    10/17/2019 7:58:25 AM - Insteon hardware interface initialization failed.
    10/17/2019 7:58:25 AM - Exit InitIO
    -----------*Pre-Error Log*----------------
    10/17/2019 7:58:25 AM - Could not contact Interface on 192.168.1.35:25105
    10/17/2019 7:58:36 AM - Warning: Unable to connect to the remote server
    10/17/2019 7:58:36 AM - You need to set the Interface Port on the Config page, and then restart HS.
    10/17/2019 7:58:44 AM - Saved ini file. msecs=15
    10/17/2019 7:58:55 AM - Submit Changes Selected
    10/17/2019 7:58:55 AM - Scheduled polling enabled.
    10/17/2019 7:58:58 AM - Warning: Unable to connect to the remote server
    10/17/2019 7:58:58 AM - You need to set the Interface Port on the Config page, and then restart HS.
    10/17/2019 7:58:59 AM - Saved ini file. msecs=0
    10/17/2019 7:59:19 AM - Warning: Unable to connect to the remote server
    10/17/2019 7:59:19 AM - You need to set the Interface Port on the Config page, and then restart HS.
    10/17/2019 7:59:36 AM - Unable to connect to the remote server
    10/17/2019 8:02:40 AM - Saved ini file. msecs=0
    10/17/2019 8:03:15 AM - Saving comm stats...
    10/17/2019 8:03:15 AM - ..finished saving comm stats.
    10/17/2019 8:03:43 AM - Saved ini file. msecs=15
    anything I'm missing or ideas? I did backup and restore HS to migrate the configuration, so unsure if that might have done something?
    thanks!
    The IP of your Insteon interface changed....
    they are set to DHCP and theres' no way to set a fixed IP, the only way to make it not change is to go in the router and make the device a fixed IP
      mike2016 thanks Mike, the IP of the hub is the same. I have a MaC reservation for it in DHCP server. IP is 192.168.1.35. I can connect to the same IP : Port from a browser.
      Last edited by maleb; October 23, 2019, 07:29 AM. Reason: Made unwanted emoji, now I can't figure out how to remove it. LoL
        did you enter the username/pswd into the plugin config page
        also, can you confirm the firmware version of the hub via the browser
        Mark
        HS3 Pro 4.2.19.5
          mnsandler Yes, and triple checked by copy and pasting the text from what I used to login directly to the hub.
          From the browser: Firmware:1018 Build Aug 16 2019 15:58:42
            that looks fine. can you do a factory reset on the hub and try again
            if that works, just use the update interface database on config page to reprogram the hub
            Mark
            HS3 Pro 4.2.19.5
              mnsandler Hi Mark, didn't work. Any other thoughts? Again, everything was working just fine until I moved HS3 to a new host and restored the config. I could reinstall everything I guess, but kinda a pain.
                what's different about the new hs server?
                Mark
                HS3 Pro 4.2.19.5
                  It's running on a Server 2019 VM vs running on a Server 2012R2 host. i verified it wasn't a server FW issue.
                    do you think it could be firewall issue? is the new VM offsite?
                    Mark
                    HS3 Pro 4.2.19.5
                      mnsandler No, it's all on a local subnet and I disabled the server FW. Also, went in and made rules. As I mentioned earlier, I can connect to the HUB from a browser on that same VM.
                        can you post a screen shot of the plugin config page
                        Mark
                        HS3 Pro 4.2.19.5
                          Looks like the Hub was updated on Aug 16. Perhaps something with that? I went ahead and stood up a whole new instance of HS3 w/ the plug-in and same issue.
Name:	HS3 Insteon error.jpg
                            is 'user' really the correct value? all of my hubs have a username of 'admin'.
                            Mark
                            HS3 Pro 4.2.19.5
                              no, it's another account. I just typed in 'User' to ofuscate my real account name a bit. However, the 'real account' is the same as what I log directly into the Hub from a browser with. I've check that multiple times overs.
