How to auto restart the Insteon plug-in after power failure?
  • How to auto restart the Insteon plug-in after power failure?
    I'm using Inteson Hub, every time there's a power failure the plugin would stop working.
    I have to manually go into HS3 to disable plugin then re-enable it, then it works again.
    I think it's because the network switches take longer to start up than HS3, when HS3 finishes loading, it can not find the Hub on the network.
    I tried the automation rule
    IF Interface port crashs
    OR IF Interface Stops Responding
    Then Disable Interface
    AND Then Enable Interface
    But it doesn't seem to do anything.
    This same question is answered in this thread:
    https://forums.homeseer.com/forum/li...a-power-outage
