Does the PLM or HUB integrate better with your plugin?
  • Does the PLM or HUB integrate better with your plugin?
    Mark,
    Does the PLM or Hub integrate better with your plugin? I posed the same question on the unsupported HS Insteon plugin thread but I figured this is a better place to ask since I will be using your plugin.
    I think I read someone that in the past an update to the HUB caused your plugin to no longer work.
    Also, do you see in benefit between the Serial PLM and the USB PLM?
    Thank you,
    Michael,
    the PLM is probably the best controller. the response time is much lower for inbound msgs from a physical switch to HS, and it takes the whole network out of the equation.
    I prefer the serial plm over the usb one, but both perform the same. The serial plm seems to recover better during power failures.
    Mark
    HS3 Pro 3.0.0.534
      Originally posted by mnsandler View Post
      Michael,
      Thanks for the info. I don't think my computer has a serial port so I think I'm stuck going with the USB PLM.
        You could try a USB to serial adapter.
          Note that you might have to install a USB to serial driver. I did under windows. The serial PLM has been very reliable for me using the USB cable. So much so that I have a backup serial PLM in storage in the event my 15 year old PLM bites the dust.
            Do you have any experience using the USB to serial adapter? How's the reliability? Is there a specific model that you recommend?
              good to know. thanks
                I am also curious what model USB to serial adapter is popular these days. I haven't bought one in years so it would be good to know what current models work the best.
                  HomeSeer used to sell these Trendnet cables and I've got a couple in use and they work very well.
                  https://www.amazon.com/TRENDnet-Conv...2805745&sr=8-3
                  -Rupp
                    My cable is 15 years old. No idea of who made it. I can tell you that the USB to serial port driver that I use is as follows:
                      I have 2 of the Trendnet TU-S9 adapters HomeSeer used to sell. I use them for my Concord 4 alarm and a HomeSeer ADIO-100. I run HomeSeer on Linux and have had no issues with the adapters.
