Insteon Thermostat support
  • Insteon Thermostat support
    Hello, and sorry if this is already known to everyone. I was trying out the insteon plugin for HS3 through my 2242 Insteon hub. Trying to add a thermostat. Looks like it is not supported, yes? Will this be supported anytime? Here is the log with details
    :13:30 PM - Attempting to add Device 3D.6B.42
    11/2/2019 2:13:30 PM - Scheduled polling temporarily stopped.
    11/2/2019 2:13:30 PM - Calling AddRecord for 3D.6B.42 1 True
    11/2/2019 2:13:30 PM - ResourceManager::RequestExclusive for Resource 1
    11/2/2019 2:13:30 PM - ResourceManager::RequestExclusive acquired for Resource 1
    11/2/2019 2:13:30 PM - Sending command 02 6F 41 A2 01 3D 6B 42 00 00 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:True
    11/2/2019 2:13:30 PM - Sending http://10.0.0.4:25105/3?026F41A2013D6B42000000=I=3
    11/2/2019 2:13:32 PM - ..My XML buffer: 026F41A2013D6B4200000006
    11/2/2019 2:13:32 PM - Sending http://10.0.0.4:25105/1?XB=M=1
    11/2/2019 2:13:32 PM - ..Got Hub Response 02 6F 41 A2 01 3D 6B 42 00 00 00 06
    11/2/2019 2:13:32 PM - ResourceManager::ReleaseExclusive for Resource 1
    11/2/2019 2:13:33 PM - Sending Insteon ID Broadcast for '3D.6B.42'
    11/2/2019 2:13:33 PM - ResourceManager::RequestExclusive for Resource 1
    11/2/2019 2:13:33 PM - ResourceManager::RequestExclusive acquired for Resource 1
    11/2/2019 2:13:33 PM - Sending command 02 62 3D 6B 42 0A 10 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    11/2/2019 2:13:33 PM - Sending http://10.0.0.4:25105/3?02623D6B420A1000=I=3
    11/2/2019 2:13:34 PM - ..My XML buffer: 02623D6B420A10000602503D6B42462C8E2A100002503D6B42050B108F01 3602503D6B42050B108F0136
    11/2/2019 2:13:34 PM - Sending http://10.0.0.4:25105/1?XB=M=1
    11/2/2019 2:13:34 PM - Received STX 0x50 (Raw Insteon Rec):3D 6B 42 46 2C 8E 2A 10 00
    11/2/2019 2:13:34 PM - Received STX 0x50 (Raw Insteon Rec):3D 6B 42 05 0B 10 8F 01 36
    11/2/2019 2:13:34 PM - Received STX 0x50 (Raw Insteon Rec):3D 6B 42 05 0B 10 8F 01 36 Debouncing repeat.
    11/2/2019 2:13:34 PM - ..Got Hub Response 02 62 3D 6B 42 0A 10 00 06
    11/2/2019 2:13:34 PM - ResourceManager::ReleaseExclusive for Resource 1
    11/2/2019 2:13:34 PM - CheckRawMessageMatch: 01 3D 6B 42 46 2C 8E 2A 10 00 against key 0* 3D 6B 42 ** ** ** 8* 01 **
    11/2/2019 2:13:34 PM - CheckRawMessageMatch: 01 3D 6B 42 46 2C 8E 2A 10 00 against key 0* 3D 6B 42 ** ** ** 8* 02 **
    11/2/2019 2:13:34 PM - CheckRawMessageMatch: 01 3D 6B 42 46 2C 8E 2A 10 00 against key 0* 3D 6B 42 ** ** ** 8* 06 **
    11/2/2019 2:13:34 PM - CheckRawMessageMatch: 01 3D 6B 42 46 2C 8E 2A 10 00 against key 3D 6B 42 46 2C 8E 8* 03 00
    11/2/2019 2:13:34 PM - CheckRawMessageMatch: 01 3D 6B 42 46 2C 8E 2A 10 00 against key 01 3D 6B 42 46 2C 8E 1* 03 00
    11/2/2019 2:13:34 PM - CheckRawMessageMatch: 01 3D 6B 42 46 2C 8E 2A 10 00 against key 01 3D 6B 42 ** ** ** 8* ** **
    11/2/2019 2:13:34 PM - CheckRawMessageMatch: 01 3D 6B 42 46 2C 8E 2A 10 00 against key 01 3D 6B 42 46 2C 8E ** 10 FF
    11/2/2019 2:13:34 PM - CheckRawMessageMatch: 01 3D 6B 42 05 0B 10 8F 01 36 against key 0* 3D 6B 42 ** ** ** 8* 01 **
    11/2/2019 2:13:34 PM - Wait: Found a matching Insteon raw message: 01 3D 6B 42 05 0B 10 8F 01 36
    11/2/2019 2:13:34 PM - Got controller/responder type broadcast for Insteon ID 3D.6B.42 of type 050B, Firmware version 10
    11/2/2019 2:13:34 PM - Received a Direct ACK from 3D.6B.42: 3D 6B 42 46 2C 8E 2A 10 00
    11/2/2019 2:13:34 PM - An unknown Insteon device of type 050B was found.
    11/2/2019 2:13:34 PM - Please post this new device type in the forum so it can be permanently added to the plugin.
    11/2/2019 2:13:34 PM - Note: This message will be eliminated once the device type is added to the plugin.
    11/2/2019 2:13:34 PM - Received a Broadcast message from 3D.6B.42: 01 3D 6B 42 05 0B 10 8F 01 36
    11/2/2019 2:13:34 PM - Scheduled polling resumed.
    11/2/2019 2:13:34 PM - The Device Type is not supported. Check the HS Log for additional information.
    11/2/2019 2:13:34 PM - ProcessInsteonTrigger Parameters: DeviceID=Interface, Command=9C, Command2=00, Group=1
    11/2/2019 2:13:34 PM - BackgroundUpdate Thread Complete...
    you will need to use the insteon thermostat plugin
    Mark
    HS3 Pro 3.0.0.534
      Thank you for making this plugin
