After installing 2342 Mini Remotes, the ON button works, but the OFF button does not. I've tried two different 4 channel and an 8 channel version and tried every combination of linking to HS3, rescanning, and reinstalling that I could think of . Any guidance would be appreciated.
Mini Remote OFF button doesn't work
if you link the remote directly to a switch does the on/off work?
there is only one link requiredMark
HS3 Pro 3.0.0.534
I have several of the 2342 devices. Both 4 button and 8 button. I find it to be a bit tricky to create a good user experience. Here are some thoughts:
1. I don't rely on the ON/OFF status of the button. Instead, I just test for whether the button has been pressed by using the Insteon Transmits and On Command or Transmits an Off command. I test for either in the event as a trigger and then take the appropriate action. Alternatively, just test whether the device has been set or changed. It kind of depends on the use. The easytrigger toggle command works real well with these remotes.
2. With the 4 button, I just label each as one thing and it doesn't really matter where the button is pressed. Since I test for either, it works nicely.
3. On a button where the result is not obvious (ie. setting the thermostat), the event will often speak something so the user knows it was accepted. I find the LED to be mostly useless.
Below are several events to illustrate. Miniremote 1 and 2 are a 8 button and Miniremote 3 is a 4 button.
- 1 like
You don’t need to manually link a device; I just want to know if that fixes the off issue.
the plugin will create the links. Typically only one link per button is required. It defines the On settings. The Off is assumed.Mark
HS3 Pro 3.0.0.534
can you post the links from the insteon.ini file for the [device x] section in questionMark
HS3 Pro 3.0.0.534
Mark,
Here are the listings for both the 4 channel mini whose buttons can now be turned off (after I linked it to another Insteon device and a (non-linked) 8 channel mini whose buttons will not turn off.
[Device 13]
ChannelName1=a DINETTE LIGHTS
ChannelName2=b KITCHEN LIGHTS
ChannelName3=c QUIET MODE
ChannelName4=d DINETTE DRAPES
DatabaseDelta=13
DeviceID=44.B4.91
DeviceLocation=Dinette
DeviceName=4 Scene Remote
DeviceType=001B
EEValues=RBPMask=0,OpFlags1=230
FailedInteractions=10
FirmwareVer=39
HopData=1015,916,84,15
LastContact=11/1/2019 3:01:42 PM
Link 1=E2 01 34 7A B9 03 1C 01 2
Link 2=E2 02 34 7A B9 03 1C 02 3
Link 3=E2 03 34 7A B9 03 1C 03 4
Link 4=E2 04 34 7A B9 03 1C 04 5
Link 5=E2 01 06 56 A5 00 00 01 1
LinksDownloaded=1
NumLinks=5
PollingInterval=0
Protocol=3
RecentDatabaseDelta=13
SyncLinkedDevices=0
TotalInteractions=149
[Device 14]
ChannelName1
ChannelName2
ChannelName3
ChannelName4
ChannelName5
ChannelName6
ChannelName7
ChannelName8
DatabaseDelta=0
DeviceID=44.BA.7A
DeviceLocation=House
DeviceName=8 Scene Remote
DeviceType=001A
EEValues=RBPMask=0,OpFlags1=22
FailedInteractions=0
FirmwareVer=39
HopData=67,64,3,0
LastContact=11/1/2019 3:21:48 PM
Link 1=E2 02 34 7A B9 00 00 02 1
Link 2=E2 01 34 7A B9 00 00 01 2
Link 3=E2 04 34 7A B9 00 00 04 3
Link 4=E2 03 34 7A B9 00 00 03 4
Link 5=E2 06 34 7A B9 00 00 06 5
Link 6=E2 05 34 7A B9 00 00 05 6
Link 7=E2 08 34 7A B9 00 00 08 7
Link 8=E2 07 34 7A B9 00 00 07 8
LinksDownloaded=1
NumLinks=8
PollingInterval=0
Protocol=3
RecentDatabaseDelta=0
SyncLinkedDevices=0
TotalInteractions=6
logbuilder
Cunning!!
Coming from StarGate, this gets around the missing "idle" mode.
Works great.
Thanks again!
[Device 13]
DatabaseDelta=13
DeviceID=44.B4.91
DeviceType=001B
FirmwareVer=39
LinksDownloaded=1
NumLinks=5
PollingInterval=0
Protocol=3
SyncLinkedDevices=0
[Device 14]
ChannelName1
ChannelName2
ChannelName3
ChannelName4
ChannelName5
ChannelName6
ChannelName7
ChannelName8
DatabaseDelta=0
DeviceID=44.BA.7A
DeviceType=001A
FirmwareVer=39
HopData=67,64,3,0
LinksDownloaded=1
NumLinks=8
PollingInterval=0
Protocol=3
SyncLinkedDevices=0
TotalInteractions=6
Mark
HS3 Pro 3.0.0.534
Originally posted by Haxster View PostIt's working now.
Thanks for your advice.Mark
HS3 Pro 3.0.0.534
Yes. Both versions are working well (so far) with the "fix" and using logbuilder's "Insteon Transmits and On Command or Transmits an Off command" suggestion.
These Insteon Minis are pretty nice. I just wish they weren't so pricey. (The old similar X-10 remotes or their "palms" could be had for around $5).
