Mini Remote OFF button doesn't work
  • mnsandler
    thanks again. Smarthome will have a 20% off sale in January if history repeats itself. And if you regularly buy directly from Smarthome, they do sent out 50% one-time use coupons every once in a while.
  • Haxster
    Yes. Both versions are working well (so far) with the "fix" and using logbuilder's "Insteon Transmits and On Command or Transmits an Off command" suggestion.
    These Insteon Minis are pretty nice. I just wish they weren't so pricey. (The old similar X-10 remotes or their "palms" could be had for around $5).
  • mnsandler
    Originally posted by Haxster View Post
    It's working now.
    Thanks for your advice.
    thanks for reporting back. i would be interested to know if this process will fix your 4 btn remote as well
  • Haxster
    It's working now.
  • mnsandler
    Mark,
    Here are the listings for both the 4 channel mini whose buttons can now be turned off (after I linked it to another Insteon device and a (non-linked) 8 channel mini whose buttons will not turn off.
    [Device 13]
    ChannelName1=a DINETTE LIGHTS
    ChannelName2=b KITCHEN LIGHTS
    ChannelName3=c QUIET MODE
    ChannelName4=d DINETTE DRAPES
    DatabaseDelta=13
    DeviceID=44.B4.91
    DeviceLocation=Dinette
    DeviceName=4 Scene Remote
    DeviceType=001B
    EEValues=RBPMask=0,OpFlags1=230
    FailedInteractions=10
    FirmwareVer=39
    HopData=1015,916,84,15
    LastContact=11/1/2019 3:01:42 PM
    Link 1=E2 01 34 7A B9 03 1C 01 2
    Link 2=E2 02 34 7A B9 03 1C 02 3
    Link 3=E2 03 34 7A B9 03 1C 03 4
    Link 4=E2 04 34 7A B9 03 1C 04 5
    Link 5=E2 01 06 56 A5 00 00 01 1
    LinksDownloaded=1
    NumLinks=5
    PollingInterval=0
    Protocol=3
    RecentDatabaseDelta=13
    SyncLinkedDevices=0
    TotalInteractions=149
    [Device 14]
    ChannelName1
    ChannelName2
    ChannelName3
    ChannelName4
    ChannelName5
    ChannelName6
    ChannelName7
    ChannelName8
    DatabaseDelta=0
    DeviceID=44.BA.7A
    DeviceLocation=House
    DeviceName=8 Scene Remote
    DeviceType=001A
    EEValues=RBPMask=0,OpFlags1=22
    FailedInteractions=0
    FirmwareVer=39
    HopData=67,64,3,0
    LastContact=11/1/2019 3:21:48 PM
    Link 1=E2 02 34 7A B9 00 00 02 1
    Link 2=E2 01 34 7A B9 00 00 01 2
    Link 3=E2 04 34 7A B9 00 00 04 3
    Link 4=E2 03 34 7A B9 00 00 03 4
    Link 5=E2 06 34 7A B9 00 00 06 5
    Link 6=E2 05 34 7A B9 00 00 05 6
    Link 7=E2 08 34 7A B9 00 00 08 7
    Link 8=E2 07 34 7A B9 00 00 07 8
    LinksDownloaded=1
    NumLinks=8
    PollingInterval=0
    Protocol=3
    RecentDatabaseDelta=0
    SyncLinkedDevices=0
    TotalInteractions=6
    the links for the 8 btn do not look correct. i would do a factor reset on the device, and then use the plugin to reprogram the device. you do not need delete the device from the plugin to do this.
  • Haxster
    logbuilder
    Cunning!!
    Coming from StarGate, this gets around the missing "idle" mode.
    Works great.
    Thanks again!
  • Haxster
    Mark,
    [Device 13]
    DatabaseDelta=13
    DeviceID=44.B4.91
    DeviceType=001B
    FirmwareVer=39
    LinksDownloaded=1
    NumLinks=5
    PollingInterval=0
    Protocol=3
    SyncLinkedDevices=0
    [Device 14]
    ChannelName1
    ChannelName2
    ChannelName3
    ChannelName4
    ChannelName5
    ChannelName6
    ChannelName7
    ChannelName8
    DatabaseDelta=0
    DeviceID=44.BA.7A
    DeviceType=001A
    FirmwareVer=39
    HopData=67,64,3,0
    LinksDownloaded=1
    NumLinks=8
    PollingInterval=0
    Protocol=3
    SyncLinkedDevices=0
    TotalInteractions=6
  • mnsandler
    can you post the links from the insteon.ini file for the [device x] section in question
  • Haxster
    logbuilder,
    Thanks for sharing your experience, insights and example. I look forward to trying out your suggestions soon.
    I'm still rather early on the learning curve.
    HomeSeer is way different than the x10-centric StarGate system that I'm migrating from.
  • Haxster
    Mark,
    Yes that seemed to get the OFF buttons to work.
  • mnsandler
    You don’t need to manually link a device; I just want to know if that fixes the off issue.
    the plugin will create the links. Typically only one link per button is required. It defines the On settings. The Off is assumed.
  • logbuilder
    I have several of the 2342 devices. Both 4 button and 8 button. I find it to be a bit tricky to create a good user experience. Here are some thoughts:
    1. I don't rely on the ON/OFF status of the button. Instead, I just test for whether the button has been pressed by using the Insteon Transmits and On Command or Transmits an Off command. I test for either in the event as a trigger and then take the appropriate action. Alternatively, just test whether the device has been set or changed. It kind of depends on the use. The easytrigger toggle command works real well with these remotes.
    2. With the 4 button, I just label each as one thing and it doesn't really matter where the button is pressed. Since I test for either, it works nicely.
    3. On a button where the result is not obvious (ie. setting the thermostat), the event will often speak something so the user knows it was accepted. I find the LED to be mostly useless.
    Below are several events to illustrate. Miniremote 1 and 2 are a 8 button and Miniremote 3 is a 4 button.
  • Haxster
    So, besides programming the MINI to homeseer, I need to link the MINI directly to at least one Insteon device to allow the OFF buttons to work? Right?
    The other three buttons are working now.
    Thanks!!
  • Haxster
    Originally posted by mnsandler View Post
    if you link the remote directly to a switch does the on/off work?
    there is only one link required
    Thanks for your prompt reply.
    Yes. The on/off works and so does the dim/bright.
    What do you mean only one link required?
  • mnsandler
