Mini remote 8 issue
    Mini remote 8 issue
    Hello,
    I added the new Mini Remote 8 and all went fine but when I press B it turns on and off B but when I press D it turns On and off B
    I've tried two new Mini Remotes and they are both doing the same thing.
    D never turns ON only B reacts in its place both when D or B are pressed
    See the screen.
    can you post the link entries from the insteon.ini for the device in question. i need to make sure the default links are correct. can you also provide a similar screen shot as above, but include the Address field as well
    Mark
    HS3 Pro 3.0.0.534
      Thank you and here they are.
      Mark
        the links for the device don't look right. i would factory reset the remote (see the user guide), and then use the plugin to reprogram it. no need to delete from plugin.
        Mark
        HS3 Pro 3.0.0.534
          also, what plugin version are you running?
          Mark
          HS3 Pro 3.0.0.534
            I upgraded the latest Beta thinking that there may be a problem with my previous version
            3.0.7.12
            I will do factory reset and see what happens.
            Thanks for now!!!
            Mark
              Doing the factory reset did the trick. Thank you!!!!
