Hi Mark, I could really use your help on one of my installations.
It is HS3 with Insteon plugin, latest version. In HS2 I used a PLM in this house. Since then, I disabled HS2 and started using Insteon hub 2242-222. Now, I am trying HS3 with your plugin. Yes, the insteon communication is not great in this house because some of the switches are from 2006 (too much work to replace all of them). Anyway, to my problem.
This 2242-222 hub works great with Insteon hub app. Another words, I get on/off working without retries, instant response. Same switch working through HS3 with Insteon plugin does not work reliably. When I do "test communication" function, I get good results on some switches, and bad on others. So, I am trying to understand why I have reliable control from Insteon hub app and unreliable from Insteon plugin? The hub is same for both apps, the connectivity is same, switches are same. What can i do to debug this.
Thank you
Felix
Thank you
Felix
