no entry for usb 2413U on config. see only Insteon hub info
  • no entry for usb 2413U on config. see only Insteon hub info
    hub died, want to use HS3. (linux on pi). want to program mini remote actions and switchlinc to replace scenes from hub
    hsinsteon was working fine..
    installed and selected this plugin..
    now what?
    you should be able to enter the linux port name into the "Interface Port", then click save, and the plugin will reconfigure the page.
    hover over the blue ? next to the field to see the potential ports available. You must tell the plugin which port. try them all if you don't know which one.
    Mark
    HS3 Pro 3.0.0.534
      ok, thanks.. that was unclear..
        /dev/ttyUSB0 is probably the right answer. the other maybe a serial port
        Mark
        HS3 Pro 3.0.0.534
          Yep, that's the one. Thanks again.
