Hi Mark,
Looking for your input before concluding to a defective device.
I have one Dimmer that always had very good communication (100% (13 failed out of 14915 cmds) 15186 1 1 Excellent)
Lately, without being 100% certain that it coincide with my upgrade to 3.0.7.1, this dimmer started to act strangely.
Do you quickly think of something I could verify avoiding me to come-up with the a wrong failure conclusion? Corruption of some-kind. I tried to Factory reset the device and reprogrammed it with no luck.
Thanks.
- Many times a day an Event sends a 50% Dim command.
- The Dimmer goes to 50% as expected.
- After between a few millisecond and 3-5 seconds it will frequently but not always go to one of the following levels : 0% (of Off. Need to confirm this one), 26%, 56%, 76%
- The last command in the log for this device will be the requested 50% (Normal logging)
- If I poll the device, the actual (26%, 56%, 76%) value will be reflected. (Still working on catching the 0% of Off one.)
Thanks.
