So, I've got the 2413U PLM configured properly and recognized by the plug-in. Wanted to add a LampLinc 2456D3 device for testing and practice, so added via the Device Management page as shown. The light plugged into the LampLinc is on, toggling via the Home page doesn't do anything. Tried deleting the device, pairing the LampLinc with the PLM using the Set buttons on each one (successfully, with two flashes from the LampLinc light), and then tried to add the device again with the same results. It's got to be something simple, but what?
Adding A Device Failing
please try the following:
delete the device from the plugin
factory reset the device (see manual)
enable detailed logging in the plugin (config page)
register the device using the Add function
post an hs log snippet of the Add log entries/transactionMark
HS3 Pro 4.2.19.5
Originally posted by MikeMcM1956 View PostMark,
Thanks, I'll give that a try and report back. On the Plugins tab in HS, my Insteon plug in only shows a single sub-tab selection for Configuration. My Z-Wave shows a bunch of different sub-tabs besides Configuration, am I missing something?Mark
HS3 Pro 4.2.19.5
post an hs log snippet of the Add log entries/transactionNov-24 12:02:05 AM Insteon ..finished saving comm stats. Nov-24 12:02:05 AM Insteon Saving comm stats... Nov-24 12:01:17 AM Device Control Device: Unknown Unknown 2456D3 LampLinc to Off (0) by/from: CAPI Control Handler Nov-24 12:01:14 AM Device Control Device: Unknown Unknown 2456D3 LampLinc to On (100) by/from: CAPI Control Handler Nov-23 11:58:24 PM Insteon Saved ini file. msecs=23 Nov-23 11:58:04 PM Insteon ** To request help with this problem please post this log file to the forum along with a detailed description of what lead to this problem. Nov-23 11:58:04 PM Insteon ** An error occurred in this plug-in. The details have been written to the log file - /usr/local/HomeSeer/Config/Insteon Error Report.Log Nov-23 11:58:04 PM Insteon ***:Forced error / log generation Nov-23 11:56:45 PM Device Control Device: Upstairs Den LampLinc 2456D3 to Off (0) by/from: CAPI Control Handler Nov-23 11:56:42 PM Device Control Device: Upstairs Den LampLinc 2456D3 to On (100) by/from: CAPI Control Handler Nov-23 11:56:39 PM Device Control Device: Upstairs Den LampLinc 2456D3 to Off (0) by/from: CAPI Control Handler Nov-23 10:15:00 PM Log Info The log database is currently 8.2MB in size.
please post 'insteon error report.log' file referenced in the above logMark
HS3 Pro 4.2.19.5
Mark,
Pardon my ignorance, but I'm a complete noob to the Rpi. How would I access the pi to find the error log you mentioned?Mark
HS3 Pro 4.2.19.5
Finally had some time today to get back to this. Shut down HS, then shut down the pi, then restarted everything. When I went to the Insteon plugin page, there was a bunch of plug-in utility functions that weren't there previously. When I was having the problem, the only thing displayed on the plugin page was the Interface info shown below.
Interface PortMaximum Hops 1234 Command Retries 123451025 Response Timeout (sec) 1235 Logging Level NoneNormalDebugDetailed Sort Device Links By TypeBy Number Enable X10
Use HS Location 2 information
Disable automatic polling
Perform group clean-ups when transmitting group commands
Now I suddenly have all the rest of what was previously missing:
You have 1 internal Insteon device(s) registered in the system, 0 external device(s), and 0 group(s).
These devices and groups currently consume 0 link database entries in your interface.*
You have 254 unused outbound link addresses out of 254 total available.
* Click the Display Interface Links button below to update this number.
There are no unregistered Insteon addresses in the network.
Plugin Utility Functions
Runs through the device and group database to add all needed local link records to the Interface
Resets the Interface and reprogram its database links
Reprograms a new interface ID across the entire network
Creates an Insteon Error Report.log file
Display the interface links to the screen. This will take a moment to load.
This will assign any device (A1 to P16) to this plugin so you can control it.
Now I'm able to register and control both Insteon and X-10 devices, all is well in the world....
Glad to hear you got it working. thanks for reporting back.Mark
HS3 Pro 4.2.19.5
- Likes 1
