In-Panel Phase Coupler
  • In-Panel Phase Coupler
    What's the best in-panel solution for Insteon and X-10?
    Mike, you don't need a phase coupler for Insteon. As long as you have at least one dual band device on each phase and they can communicate with each other, they will handle this.
    The following device was required before dual-band
    https://www.smarthome.com/signalinc-...hardwired.html
    Mark
    HS3 Pro 3.0.0.534
      Mark,
      Will the Insteon Dual Band devices also serve as a coupler for my X-10 devices as well?
        Originally posted by MikeMcM1956 View Post
        Mark,
        no, they don't repeat or forward x10 msgs
        Mark
        HS3 Pro 3.0.0.534
          So, I'll have to get one for my X-10 devices if I have any issues with the 2413U PLM not talking to them?
            i used to have an A10 CR234 x10 coupler installed. no issues with insteon signals. if you are are interested in the unit, send me an private message on this board
            Mark
            HS3 Pro 3.0.0.534
              What is the effect on hop count when using a pair of dual band devices rather than a wired signalinc?
                that is a good question, but i dont know the answer. you might find the answer at the forum at smarthome.com
                Mark
                HS3 Pro 3.0.0.534
