How to do a group like with X10
Originally posted by mnsandler View PostJust create your own device from the hs device management page
- Likes 1
Guest repliedOriginally posted by allenc3 View Post
Ah HA! Virtual Device sounds right. Where is that?
Originally posted by baudi View Post
A virtual device will still have to trigger an event. You can use your current trigger to trigger the event. You stated " I have several Events that trigger off Mini-Remote button presses and time triggers" a virtual device doesn't help in this scenario at all.
- Likes 1
Originally posted by allenc3 View PostAh HA! Virtual Device sound right. Where is that?
And there inlies the issue. You can't use one protocols proprietary grouping commands on another protocol. This is where events shine.
Yes, but I think you missed the point of my question. I don't want to use Events every time I need to control more than one device, I want to set up a named reference for a group of devices and control them as a single device. This is what baudi suggested and is a solution for Insteon devices, the rest of the solution is what I asked regarding a controllable named list of devices of mixed brands and protocols.
Originally posted by Rupp View PostWhy, this is core HS3 functionality.
What you are looking for is plugins> insteon> configuration> manage groups
But I note that Groups work only with Insteon devices, is there a way to have a similar type group reference that contains Insteon, X10, and Z-Wave devices in HomeSeer? This is the main reason I have always used HS instead of software that only controls one brand of device, I want the flexibility of controlling any brand device but I need device independent references that are controllable as though they were a device. Right now I have several Events that trigger off Mini-Remote button presses and time triggers, but there is no Event reference that can be controlled like a device that I know of. Example, say I have a list of devices in HS consisting of 5 Insteon, 3 X10, and 3 Z-Wave devices and I want to call this Holiday Lights. Then I want to issue a command like "Holiday lights ON" or "Holiday Lights 50%". Is this possible? Can I create a variable name that would trigger an Event?
