Brian,
you will need to use the following two actions: Insteon Disable Interface or Insteon Enable Interface.
1. have you created the virtual device Joe mentioned above? the name & parameters don't matter. you just need this to hold a temporary value of your choosing. when the event runs the first time. and then to clear the value when power is restored
2. have you built an event to disable the plugin when your power monitor devices goes on, ie power loss? the trigger is up to you
3. do you have an event to enable the plugin when power is restored based on your device when it goes off? again the trigger is up to you
if so, please post a screen shot of the configuration, and i can comment from there
ok. so the generator isnt the issue in this case. i can't tell you why the plm is having troubles during the flickering.
