Changing device settings by event
    Is it possible to change a device setting, i.e. Default On Level, using a timed event?
    Depending on the time of day I like to switch a micro dimmer on to a specific dimmer value. Using an triggered event is to slow. Currently I let a motion sensor switch on the light directly with a low dimmer value and let a triggered event correct the dimmer to the desired value. This introduces an annoying delay.
    If the device setting can be changed by a timed event the delay can be avoided.
    Yes, There are event actions for changing Settings and Op Flags values
    Mark
    HS3 Pro 3.0.0.534
