Mini Remote 8 Scene
    Mini Remote 8 Scene
    Mark,
    With Mini Remote Switches they work as controller for a scene okay. But is there any way to set Mini_Remote_8 Button A to On/OFF.
    I cant seem to see them in an event.
    I have the mini remotes set as 'status only' in HS. so changing the status via code or event isn't supported. These devices are controllers only. Honestly, you should probably just hide them from view. You really only need to see them for building triggers, and creating links.
    Mark
    HS3 Pro 3.0.0.534
      What I wanted to do was to have button A turn on Movie Scene and then Button B turn off Movie Scene. Maybe you could add some other state than Toggle ON or Toggle OFF.
      Like Trigger so when a scene see Button A we execute the links in the (Movie On) Group to the Hard Coded States. then we could do the do the same for Button 2 (B).
      Joe.
        Use the "Insteon special triggers" "Transmits an On Command" OR "Transmits an Off Command". That way the event triggers when the button is pushed regardless of whether it was already on or off. I use that all the time and it works great.
          Joe,
          the remotes don't support on-only toggle or off-only toggle. the 4 btn remotes have on/off on separate btns, but you get fewer controls
          Mark
          HS3 Pro 3.0.0.534
            Joe, I think this is what you're trying to do. I turn some of the buttons on my 8 button remotes into 4 button (sort of) by using:
            This way the event is triggered by Button H regardless of whether it was previously On or Off.
              Yes that's how i did it before with HomeSeer was events, but i wanted it to work with Insteon Scene.
              If Button A Transmit On
              then Set Device_Group_3_On to ON. .... this is strictly devices to On.
              If Button A Transmit Off
              then Set Device_Group_3_Off to ON. .... this is mixed mode some devices to Off and some devices to On.
              We would have to have some way in the Group to say this devices Ignore what State was being set.
              Joe.
                Joe.
                using links, you can turn devices Off even when the controller device is set On. you just have the on-level to Zero, or Off
                but if the controller is turned Off, every linked device will go Off too
                Mark
                HS3 Pro 3.0.0.534
                  Yes, that is the issue i am with this.
                    Yes, that is the issue I am having with type of programming, for scene.
                      have you tried messing with the Toggle Buttons setting. if you disable this, the button will send the same signal with each press. My guess is it sends an On, but you will need to test.
                      Mark
                      HS3 Pro 3.0.0.534
                        I don't know how to disable that button? I just tried setting the ProgOpt for toggle from default On to off works the same way.
                          You can't change a single button. its all or nothing. Did you check the hs logs to see what each button is transmitting (On or Off) with each press? what did you find?
                          Mark
                          HS3 Pro 3.0.0.534
                            YES in HS i can change Button Values. But on matter what i do they still transmit an on or off. in the logs. I even tried to change the HS group so 100 = On and 0 = Alt On.
                              Should say no matter what i set in group or in mini 8 i have changed them to 100 = On and 0 = Alt. On. Insteon just transmit an On and Off
