I have 2 Dual-Band LampLinc that I am trying to turn off/on when either is on/off
Both are set up with links to each other and have Sync linked responder device checked.
Frontdoor Front Lamp
Device Type: Dual-Band LampLinc
Firmware Version:
Comm Reliability: 100% (0 failed out of 148 cmds)
Resume dim mode: False
Default local on level: 100%
Device Link Table
Link #4 Outlet controls Living Room Lamp Outlet (3A.5B.25)
Link #2 Outlet has local control reporting to HomeSeer
Link #5 Outlet is controlled by Living Room Lamp (3A.5B.25) - On Level: 100%, Ramp Rate: .5 Sec.
Link #1 Outlet is controlled by HomeSeer using Hub Group #0 (i2CS Registration Link) - On Level: 100%, Ramp Rate: .5 Sec.
Link #3 Outlet is controlled by HomeSeer using Hub Group #254 (HomeSeer All Devices Group) - On Level: 100%, Ramp Rate: .5 Sec.
Living Room Lamp
Firmware Version: 43
Comm Reliability: 100% (0 failed out of 388 cmds)
Device Link Table
Link #5 Outlet controls Frontdoor Front Lamp Outlet (3A.47.93)
Link #4 Outlet is controlled by Frontdoor Front Lamp (3A.47.93) - On Level: 100%, Ramp Rate: .5 Sec.
Link #1 Outlet is controlled by HomeSeer using Hub Group #0 (i2CS Registration Link) - On Level: 0%, Ramp Rate: .5 Sec.
When I turn them off (either one) both turn off and HS updates both as off
When I turn Frontdoor Front Lamp on - only it comes on and both are updated to on in HS
When i turn Living Room Lamp on - only it comes on and both are updated to on in HS
LOG:
Firmware Version:
Device Link Table
Living Room Lamp
Device Link Table
LOG:
Jan-23 11:36:19 PM | Insteon | Saving comm stats... |
Jan-23 11:36:13 PM | Insteon | Setting status and value for device 3A.47.93:1. Old status:0 Old Value:0, New Status:2 New Value:100 |
Jan-23 11:36:13 PM | Insteon | Received a Direct ACK from Frontdoor Front Lamp (3A.47.93): 3A 47 93 4E AD BA 2F 2E FF |
Jan-23 11:36:13 PM | Insteon | Received STX 0x50 (Raw Insteon Rec):3A 47 93 4E AD BA 2F 2E FF |
Jan-23 11:36:13 PM | Insteon | ..Got Hub Response 02 62 3A 47 93 0F 2E FF 06 |
Jan-23 11:36:13 PM | Insteon | Sending http://XX.XX.XX.XX:25105/1?XB=M=1 |
Jan-23 11:36:13 PM | Insteon | ..My XML buffer: 02623A47930F2EFF0602503A47934EADBA2F2EFF |
Jan-23 11:36:11 PM | Insteon | Sending http://XX.XX.XX.XX:25105/3?02623A47930F2EFF=I=3 |
Jan-23 11:36:11 PM | Insteon | Sending command 02 62 3A 47 93 0F 2E FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False |
Jan-23 11:36:11 PM | Insteon | Sending sync command 46 to linked responder device: Frontdoor Front Lamp (3A.47.93) |
Jan-23 11:36:11 PM | Insteon | SyncResponderDevices called for device code: 3A.5B.25:1 |
Jan-23 11:36:11 PM | Insteon | Setting status and value for device 3A.5B.25:1. Old status:0 Old Value:0, New Status:2 New Value:100 |
Jan-23 11:36:11 PM | Insteon | Received a Direct ACK from Living Room Lamp (3A.5B.25): 3A 5B 25 4E AD BA 2F 11 FF |
Jan-23 11:36:11 PM | Insteon | Received STX 0x50 (Raw Insteon Rec):3A 5B 25 4E AD BA 2F 11 FF |
Jan-23 11:36:11 PM | Insteon | ..Got Hub Response 02 62 3A 5B 25 0F 11 FF 06 |
Jan-23 11:36:11 PM | Insteon | Sending http://XX.XX.XX.XX:25105/1?XB=M=1 |
Jan-23 11:36:11 PM | Insteon | ..My XML buffer: 02623A5B250F11FF0602503A5B254EADBA2F11FF |
Jan-23 11:36:10 PM | Insteon | Sending http://XX.XX.XX.XX:25105/3?02623A5B250F11FF=I=3 |
Jan-23 11:36:10 PM | Insteon | Sending command 02 62 3A 5B 25 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False |
Jan-23 11:36:10 PM | Insteon | CAPIControl: Label=On, Value=100, ControlType=Button |
Jan-23 11:36:10 PM | Device Control | Device: Downstairs Living Room Lamp to On (100) by/from: CAPI Control Handler |
