Originally posted by mnsandler
View Post
Where are links between devices stored?
- Likes 1
Originally posted by allenc3 View Post
OH yes, I see that now, very useful. I edited a ramp rate and On dim level for a lamp link that I could not understand why there where two different dim levels when turning on from HS3 and Mini button. I see that we can edit a link and delete a link not not create a link. Or is that create link between two devices at bottom of page how we create a new link? I thought that was real-time control between two devices being done through HS3 like an event can do. Are you saying that creates a link in the two device databases the same as when we click a controller button and click a responder button? Can we create more than one link? I don’t see how because there is only a place for one link per device.
the create link section allows you to create links between the given device, and any device that shows in the responder list. but you can only have one link from a controller to a given responder.
Originally posted by allenc3 View Post...Or is that create link between two devices at bottom of page how we create a new link? I thought that was real-time control between two devices being done through HS3 like an event can do. Are you saying that creates a link in the two device databases the same as when we click a controller button and click a responder button? Can we create more than one link? I don’t see how because there is only a place for one link per device.
- Likes 1
Originally posted by mnsandler View PostEdit links is available from a given device
How do you create links between devices in the plugin? I do not see that command on the Device Link Table page. I see Delete selected links and Update selected links but no option to create additional links.
- Likes 1
the existing links will not be overwritten. the plugin will read the existing links and then write its new links in free space in the database. if the plugin can reuse the existing links, it will otherwise it will write additional links.
Thanks, what about existing links in the switches? Are they overwritten or remain in addition to links via HS?
Yes, it's way better to create the links via HS. The links are still programmed into the devices, and the links still work when HS is off.
Tom
most insteon devices have an internal link database to store links. The PLM also has a link database. I would recommend using my plugin to create/manage all the links. the links will still work even if HS isn't running.
Where are the links between devices actually stored when initiated from HS. My practice has been to manually create links between devices that by the nature of their installation, must be linked. For example, two Insteon Switches installed in a 3-way switch arrangement. By manually creating essential links the switches function regardless if the HomeSeer is connected or not. We are now automating our 4th home. I did not have to change any switches or rewire travelers in the previous houses after we sold them.
When I use HS and the Insteon Plug-in, if the links are store in the actual switches (PLCs) then I should not have to do any manual links.
Tom.Tags: None
