Dual-Band LampLincs Randomly Turn On / Off
    Mark having issues with lamplincs turning on/off randomly. (we had another thread where they would not link you updated plugin to fix)
    Both are same version and linked and the only 2 Lamplincs I have. I have tried to remove them and re-add but same result.
    Not sure if its relevant but when other lights are turned off and on they seem to go on/off as well also I have several occupancy sensors which may be causing the frequent on/off when they send heartbeats or motion detection (none of the sensors are set to control the LampLincs).
    Device Type: Dual-Band LampLinc
    Firmware Version: 43
    Comm Reliability: 100% (1 failed out of 374 cmds)
    Resume dim mode: False
    Default local on level: 100%
    Below logs show frequency
    Mar-24 10:33:48 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:33:48 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:32:58 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:32:56 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:31:52 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:31:50 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:27:30 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:27:28 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:25:52 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:25:50 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:25:16 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:25:15 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:24:45 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:24:43 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:24:17 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:24:15 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:23:49 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:23:47 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:23:09 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:23:09 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:22:35 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:22:35 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:21:53 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:21:51 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:21:09 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:21:07 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:20:39 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:20:37 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:20:09 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:20:07 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:19:15 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:19:13 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:18:23 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:16:55 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:16:25 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:16:25 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:15:47 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go OFF
    Mar-24 10:15:45 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Mar-24 10:15:10 AM Insteon Received Frontdoor Front Lamp (3A.47.93) Go ON
    Anyway since we have been quarantined it has gotten worse several times an hour (why I think occupancy sensors may play a role) and the wife is tired of it lol
    Let me know if you need anything.
    Steven G
    what do the links look like in the Frontdoor Front Lamp device within the plugin
    Mark
    HS3 Pro 3.0.0.534
      Link #2Outlet controls Living Room Lamp Outlet (3A.5B.25)
      Link #4Outlet has local control reporting to HomeSeer
      Link #1Outlet is controlled by Living Room Lamp (3A.5B.25) - On Level: 100%, Ramp Rate: .5 Sec.
      Link #3Outlet is controlled by HomeSeer using Hub Group #0 (i2CS Registration Link) - On Level: 0%, Ramp Rate: .5 Sec.
      Link #5Outlet is controlled by HomeSeer using Hub Group #254 (HomeSeer All Devices Group) - On Level: 100%, Ramp Rate: .1 Sec.
      Steven G
        Also just noticed this in log
        Mar-24 11:23:43 AM Insteon Program Remote Record not needed for 3A.47.93 to E2014EADBA000001
        Mar-24 11:23:25 AM Insteon Trouble converting [] to integer
        Mar-24 11:20:31 AM Insteon Received Office Motion Sensor - Occupancy Sensor Occupancy Sensor: (41.65.37) Go OFF
        Mar-24 11:17:45 AM Insteon Received Office Motion Sensor - Occupancy Sensor Occupancy Sensor: (41.65.37) Go ON
          Steven G
          Link #1 (the living room lamp) is controlling the Frontdoor Front Lamp. is this desired? if not, delete this link
          Mark
          HS3 Pro 3.0.0.534
            I think updating to the latest beta in the Updater will resolve the above error
            Mark
            HS3 Pro 3.0.0.534
              Yes it is correct when one is turned on the other should as well
              here is thread where we worked on that LINK
                I am on version 3.0.7.18 the version available in beta is 3.0.7.1. That correct?
                Steven G
                  Steven G
                  3.0.7.1 is the current Release version.
                  3.0.7.18 is a beta, and should be fine for now.
                  Mark
                  HS3 Pro 3.0.0.534
                    do you have any events that turn on the outside light based on a motion sensor?
                    Mark
                    HS3 Pro 3.0.0.534
                      no all motion is for indoor rooms, but was playing with the links and I removed the links from frontdoor lamp 1 by 1 and re-added and looks like it may have fixed it.
                      I will keep an eye and report back
                      Steven G
                        Steven G
                        Ok, thanks for trying that. please report back if that takes care of the issue.
                        Mark
                        HS3 Pro 3.0.0.534
