Insteon Hidden Door Sensor Battery Level and others
  • mnsandler
    device #2 only goes on/off if you change the device option (so typically you can hide this device). the heartbeat only goes on for a second when the heartbeat is received (see last updated date) otherwise its off. the battery level should display a value. and the low battery device is unreliable
  • scaleste
    I believe they are linked to the PLM correctly. Below are screen shots of the Insteon properties for two of the sensors. The second with a send battery lever every 10 heartbeats provides a battery level. That is obvious and I will make an adjustment to the four that has "0" for that value. However, in all 5 cases the 4 channels other than the Open/Closed status indicate "Off" for each of the Sensors. Any idea what is going on.
  • mnsandler
    the heartbeat should update the other channels periodically. if you aren't getting the heartbeat, make sure the device is linked to the interface (plm, or hub)
  • scaleste
    started a topic Insteon Hidden Door Sensor Battery Level and others
    I have just installed 5 Insteon Hidden Door Sensors. I noticed that while the door sensors worked flawlessly, HS show,4 of the 5 channels "Off" and no indication where to turn them on. How do I turn on the additional channels such as Battery Level.
