Computer "high power usage" from plug in
    I am running my Homeseer software on server hardware with Windows 10. Every now and then the fans on the server kick in to high mode and sounds like a jet taking off. When I look at Task Manager I always find the Insteon plug in showing high power usage. If I shut down Homeseer the fans ramp back down. I start Homeseer back up and everything is fine for awhile until the same process happens. Has anyone else had this issue?
    Dan
    are you running any insteon actions or events when this occurs? can you coorelate it to what is happening in the log? maybe enable detailed logging in the plugin
    Mark
    HS3 Pro 4.2.19.5
      I have two schedules to turn lights on and off in the morning and evening but that is it. I will enable the detailed logging to see if this provides any info.
        do you use the device polling feature within the plugin?
        Mark
        HS3 Pro 4.2.19.5
          I do not have the box checked to disable polling. Should I try disabling it?
            do you have non-zero values set as the "Pol Inv." for your devices? if so, what are they.
            Mark
            HS3 Pro 4.2.19.5
              does this correlate to high CPU utilization?
              Mark
              HS3 Pro 4.2.19.5
