I know this isn't exactly an Insteon topic but you guys know a lot about home automation. I've looked around and cannot find what I want. I use HS3 Sunset and Sunrise times to turn on and off lights around the house but there are many days when cloud cover makes the house interior pretty dark for about an hour before the lights turn on from Sunset time. I would like to "OR" in logic from an outdoor or through-a-window photo sensor that can read out light intensity values. Does something like this exist in Insteon or Z-Wave? I can't find anything.
Need outdoor light Dusk Dawn light level sensor
The new insteon motion sensors have a light sensor built in and report out a level. you can even set the dawn and dusk levels yourself which will trigger the dawn/dusk sensor to on/off.Mark
HS3 Pro 3.0.0.534
- 1 like
Originally posted by mnsandler View PostThe new insteon motion sensors have a light sensor built in and report out a level. you can even set the dawn and dusk levels yourself which will trigger the dawn/dusk sensor to on/off.
Edit: It’s the Motion Sensor II me thinks.
Mark
HS3 Pro 3.0.0.534
Mark
HS3 Pro 3.0.0.534
The new Motion Sensor II only sends its temperature and light level data when it detects motion, making it not so useful as a temperature or light level sensor. I'm sure that's to save the battery, which wouldn't last long if it was continuously transmitting temperature and light data. However, I read somewhere that it if you power it with the USB plug (under the battery), it will send continuous data. I have not tested that, can anyone confirm this is true?
- 1 like
the motion sensor will send the light level with every heartbeat; you can change that frequency to match your needs. using the usb cable is a good option.Mark
HS3 Pro 3.0.0.534
- 1 like
The default night and day thresholds are adjustable in the plug-in. The Defaults are 64 and 80. What do the values represent? I am assuming that 80 and above are bright and below 64 is dark for Night. As for the Transition Interval (m:s), with the sensor send the Dusk/Dawn status once the threshold is reached and interval lapsed or will it wait for a heartbeat to be sent?
