Hidden Door Sensor - LED and Beeper disable
    I was trying to disable the LED and beeper in my Insteon Hidden Door Sensor (2845-222) but can only get the Insteon Operating Flags to set the LED = Single, and not OFF.
    Anyone got any ideas how to disable the LED completely? Wanted to save some battery juice. Also, the Insteon docs state the LED and Beeper can be disable in "Software Only Features".
    Andrew
    a bug in the option lists.
    there should be an Off option in the LED list; set that and program it
    Mark
    HS3 Pro 3.0.0.534
      I see the same issue showing up. Appears that there are four options in the LED list per the attached screenshot.
      I'm running Plugin 3.0.7.19
      Even if you select Off and program that option, it reverts back to Single when you enter the edit device details page.
        Yah, this is a bug which i already fixed, i just need to post the update
        Mark
        HS3 Pro 3.0.0.534
          please try beta 3.0.7.21 in the beta section of the Updater
          Mark
          HS3 Pro 3.0.0.534
            Closing the loop.. this appears to have resolved that issue. UI is clean now.
              thanks. and do the LED options work correctly when you set them?
              Mark
              HS3 Pro 3.0.0.534
