Dirty shutdown resulted in new ini file
    Mark, I had a dirty shutdown last night. The log shows when HS restarted that the plugin did not have a COM port set. I set it, and the log shows it started communicating with the PLM. All devices showed up in HS, but no control was happening. I finally went into the plugin's devices page, and nothing was there! I checked the ini file and it was 1 KB. Well, that would explain why there was no COM port set. I disabled the plugin and restored from a backup ini. (I was scared because the "Insteon - Backup.ini" was from over three years ago. Good thing I have a daily backup of the HS directory via BLBackup, so I restored from yesterday's backup. Only after restoring from that did I see that backups are now called insteonN.ini. Obviously, I haven't had to revert to a backup ini in years.) I restarted the plugin, all devices showed up in the plugin's device's page. I let out a huge sigh of relief.
    Anyway, I have had dirty shutdowns before and this has never happened. Is it just something that always has a risk of occurring when that happens? Without knowing what happened to the ini during system reboot and/or HS startup (was it deleted, was it saved with no data in it), should the plugin have automatically restored from the most recent backup, or is it always meant to be a manual operation?
    Scott
    Scott, what plugin version are you running?
    I have had a lot of trouble with HS truncating my ini file when HS crashes. The most recent release and betas have my own ini management code. I haven't considered automatically restoring an ini file if the current one is empty (an interesting idea). I would want to ask the user during startup which i don't think i can do. it would halt unattended restarts.
    Mark
    HS3 Pro 4.2.19.5
      3.0.7.23 and have been for some time, but I don't recall exactly when I updated it and from what version, but I think it was .20.
        can you confirm if you have an insteon device on the dev mgmt page that also has a copy of your insteon.ini on the insteon tab?
        Mark
        HS3 Pro 4.2.19.5
          Mark, I apologize for the late reply. I didn't get a notification that you had replied. (I checked my forum settings and reply notification is enabled. I haven't been getting any reply notifications to recent HS forum threads I started, so I just have to check manually. I have a daily digest notification enabled for this forum/channel.)
          Anyway, yes, I do have a device named "Insteon Plugin" with the ini file contents on the Inseon tab. I don't recall that I have noticed this device before, let alone that the ini file contents are on the Insteon tab.
          Scott
            I added this device and content, so in the event that a user has to restore a homeseer db, we can recreate the matching insteon.ini from the db directly
            Mark
            HS3 Pro 4.2.19.5
              I'm using 3.0.7.19 and do not see this Insteon Device. Should I update to 3.0.7.25?
                  look for the a device called "Insteon Plugin"
                  Mark
                  HS3 Pro 4.2.19.5
                    HS3 on Zee S2: Top Menu PLUG-INS/Insteon/Configuration/Manage Devices, in Table "Currently Registered Insteon Devices", Column: "Device", there is no such device as "Insteon Plugin". There are only the 24 internal physical Insteon devices I added.
                      this is a HS device on the device management page somewhere, not a device within the plugin
                      Mark
                      HS3 Pro 4.2.19.5
                        Ah yes, found it and found the Insteon tab and all the ini text. Thx.
                          Hopefully, you will never need it but its there just in case. I was having too many users not being able to restore an insteon.ini with their homeseer.hsd file
                          Mark
                          HS3 Pro 4.2.19.5
