I naturally thought that I could trigger on an ON and an OFF on every button of a keypad. But it seems that the event create logic wants to disagree and not let me...
This reverts back to wanting a Dim(value)% , so how do you trigger just a press in toggle mode if you wish to light to show?
I cannot figure out if it is a limitation of the keypad device itself, the HS3 event logic getting in the way, or something specific with Insteon plugin...
EDIT: I just realized that it is ONLY with the ON that this weird behavior happens, the OFF is a valid event config. I just "assumed" makes an *** of me! that OFF was the same...
Help?
A
Help?
A
