Anything to report? the other user's system is running pretty well
Micro-open-close-module does not completely open screen...solved
Mark
HS3 Pro 3.0.0.534
Until now the system is functioning without any crash. Sometimes I notice a new message:but that does stop the system from operating.Sep-09 20:23:18 Insteon Hub.GetXMLBuffer still busy
Also I notice sometimes a buffer write/get of several seconds but the system stays operational then also.
Yes this is all expected and normal.
I realized the the hub is just going to take its time. And I have to left itMark
HS3 Pro 3.0.0.534
Everything still working ok? can you post a log file? I'm curious to see your times.
One thing, I believe you currently have the Advanced/Get Buffer Interval set at 2000. this will affect how quickly the plugin can respond to an inbound msg from say a motion sensor or switch that you use as a trigger. You might try dropping this to 1000 if you need a quicker response. Otherwise 2000 is the current default.Mark
HS3 Pro 3.0.0.534
That's good new. thanks for the log. it looks very clean. you might notice a few more Busy messages with a lower buffer interval, but it shouldn't be a problem.
To stress test it, I've run tests at 30 and 40 msecs, and it continues to work. but the down side is it can block up the hub so some device msgs are missed.Mark
HS3 Pro 3.0.0.534
Originally posted by JeroenvV View PostStill going strong with 1000 ms.
btw what is your other hub setting "Response Time (secs)"?Mark
HS3 Pro 3.0.0.534
Originally posted by JeroenvV View PostResponse Time is set to 3 secs
in general, lower numbers will make the plugin seem more responsive when you use triggers based on insteon messages, or control devices from the UI and see a delay in the update in the UI.
the other user is is running at 2000 and 2 respectively without issue.he only has about 10 registered devices (so a small installation)Mark
HS3 Pro 3.0.0.534
great. thanks for reporting back.Mark
HS3 Pro 3.0.0.534
