Before I delete my devices in the HS Plugin...
  • Burrington
    Originally posted by allenc3 View Post
    If you know the six hexadecimal digit Insteon address then yes you can add it manually using Mark’s plugin.
    Yes, and without having to access the set button...
    The only devices you have to use the set button for are any RF-only devices like motion sensors, mini-remotes, etc.
    You're going to love Mark's plugin.
  • allenc3
  • JRose
    started a topic Before I delete my devices in the HS Plugin...
    I want to switch to Mark's plugin but before I delete all my devices in HS, I have a few of flood lights controlled by In-line linc boxes waaaaay up high in the electrical boxes at the roof peaks. I really don't want to climb up there and disassemble the fixture to press the set button. Can these be added manually in the plugin if I have the details from the HS ini file?
