Mark, when a wireless device such as a door sensor sends a heartbeat indication, does it also send its current status? If so, would it be possible to update the HS Device status to match the physical device when the heartbeat is received?
Reason: I use Insteon Door/Window sensors to detect if the windows on my RV are open. Because the system is only running when the RV is in use, the status of the sensors is not known until the window is opened or closed. It would be really nice if the status would update automatically with the heartbeat if that was possible.
Another reason: If the actual change of status from the device was missed (system reboot, bad communication, etc), the status would at least update when the heartbeat came in. Could be a lifesaver for a missed water leak indication.
