I just replaced my Insteon Hub 2 with the USB PLM. The plugin recognizes the PLM and I'm able to use the PI to "tap add" devices. However, I am not able to control the devices from HS3.
The PLM is receiving signals because I can turn on a device from the switch and the device's status is updated on HS. If I try to control that same device from HS nothing happens.
When I use the PI to test communications I get 100% failure, 100% of the time.
I didn't have any issues with the Hub. (I know, if it's not broken don't fix it). However, I've read several times on this board that the PLM is the optimal device for HS for a variety of reasons.
What am I doing wrong?
Please advise. Thank you in advance for your assistance.
