Problem with hidden door sensor
    A strange error occurred after closing a hidden door sensor.
    Apparently the sensor repeatedly sent the off signal.
    Jun-19 20:36:00 Insteon ** To request help with this problem please post this log file to the forum along with a detailed description of what lead to this problem.
    Jun-19 20:36:00 Insteon ** An error occurred in this plug-in. The details have been written to the log file - /home/HomeSeer/Config/Insteon Error Report.Log
    Jun-19 20:36:00 Insteon ***:Error in HiddenDoorSensor.ProcessGroupBroadcast: Conversion from string "1E" to type 'Integer' is not valid. -- Details System.InvalidCastException: Conversion from string "1E" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in a correct format. at System.Number.StringToNumber (System.ReadOnlySpan`1[T] str, System.Globalization.NumberStyles options, System.Number+NumberBuffer& number, System.Globalization.NumberFormatInfo info, System.Boolean parseDecimal) [0x0004b] in :0 at System.Number.ParseInt32 (System.ReadOnlySpan`1[T] s, System.Globalization.NumberStyles style, System.Globalization.NumberFormatInfo info) [0x0000c] in :0 at System.Int32.Parse (System.String s) [0x00019] in :0 at Microsoft.VisualBasic.CompilerServices.IntegerType.FromStrin g (System.String Value) [0x00018] in :0 --- End of inner exception stack trace --- at Microsoft.VisualBasic.CompilerServices.IntegerType.FromStrin g (System.String Value) [0x00055] in :0 at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger (System.String Value) [0x00001] in :0 at Insteon.Support.Devices.HiddenDoorSensorClass.ProcessGroupBr oadcast (Insteon.Support.Core.InsteonModule+TransmitMsgType Msg, System.Boolean RemoteMsg) [0x00000] in <291ee717f12342bcb18b9e09c086bb2b>:0
    Jun-19 20:35:36 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go OFF
    Jun-19 20:35:13 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go OFF
    Jun-19 20:34:45 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go OFF
    Jun-19 20:33:09 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go OFF
    Jun-19 20:33:00 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go OFF
    Jun-19 20:32:45 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go OFF
    Jun-19 20:22:39 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go OFF
    Jun-19 20:22:36 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go OFF
    Jun-19 20:22:36 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go ON
    Jun-19 20:22:21 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go OFF
    Jun-19 20:22:21 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go ON
    Jun-19 20:22:12 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go OFF
    Jun-19 20:22:12 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go ON
    Jun-19 20:22:07 Insteon Received Woonkamer Schuifpui sensor - Door Sensor Door Sensor: (2B.0F.95) Go OFF
    And the log file
      this is not a fatal error. the plugin just received a bad message and couldn't convert a value
      Mark
      HS3 Pro 3.0.0.534
        Thanks for the quick response again. The message looked alarming. Good to know it is not serious.
