Hi Mark,
I am wondering why HSPI_Insteon.exe takes almost 40 seconds to terminate after HomeSeer has shut down.
I've noticed this for a while now. Just updated to 3.0.7.26 and still the same...
Date/time=2020-06-19 5:19:27 PM PDT
Version=HS4 Pro Edition 4.0.9.0 (Linux)
License=Registered
Uptime=0 Days 0 Hours 4 Minutes 29 Seconds
Lan IP=192.168.1.103 (Debian10)
Device Count=150
Event Count=53
Plugins Enabled=Pushover 3P:,SDJ-Health:,Insteon:,drhsEventEnabler:,Z-Wave:,mcsMQTT:
Modules/Threads=77 Modules, 64 Threads
Available Threads=399
HomeSeer Memory Used=154 Mbytes
Plugins Installed=Current Cost 3P 0.0.0.42,drhsEventEnabler 1.0.0.0,Harmony Hub 4.0.11.0,Insteon 3.0.7.26,JowiHue 4.0.1.0,mcsMQTT 5.2.4.9,NetCAM 3.0.0.14,Philips Hue 4.0.16.0,Pushover 3P 0.0.0.48,SDJ-Health 3.0.8.6,Zigbee 4.0.6.0,Z-Wave 3.0.2.0
License=Registered
Device Count=150
Event Count=53
HomeSeer Linux starting...
05:06:36:2764:[Database]->Opening (Mode=Read Only) up HomeSeer LOG database /usr/local/HomeSeer/Logs/HomeSeerLog.hsd
05:06:36:4439:[Startup]->Loading Settings
05:06:36:5028:[Startup]->Settings Loaded.
05:06:37:1913:[Startup]->
05:06:37:1916:[Startup]->*********************************************************** *********************
05:06:37:1921:[Startup]-> HomeSeer version 4.0.9.0 Edition: HS4 Pro Starting Now
05:06:37:1923:[Startup]->*********************************************************** *********************
05:06:37:1925:[Startup]->
05:06:37:1993:[Startup]->Creating Class Objects...
05:06:37:2003:[Startup]->COM port classes started.
05:06:37:2018:[Startup]->Application interface class started.
05:06:37:2037:[Startup]->Web server class started.
05:06:37:2042:[Startup]->E-Mail SEND class started.
05:06:37:2044:[Startup]->E-Mail RECEIVE class started.
05:06:37:2058:[Startup]->Plug-In Interface class started.
05:06:37:2066:[Startup]->Local voice recognition class started.
05:06:37:2078:[Startup]->Loading configuration file ...
05:06:37:4420:[Database]->Loaded 150 Devices.
05:06:37:5324:[Database]->Loaded 53 Events.
05:06:37:5328:[3]->Unable to load counters config file, trying backup
05:06:37:5330:[4]->Unable to load counters from normal or backup file!
05:06:37:5334:[3]->Unable to load timers config file, trying backup
05:06:37:5336:[4]->Unable to load timers from normal or backup file!
05:06:37:5376:[Startup]->HomeSeer version is: 4.0.9.0
05:06:37:5379:[Startup]->Creating Speaker Client Interface Object...
05:06:37:5394:[Startup]->This version of HomeSeer is registered as a HS4PRO version.
05:06:37:5455:[Web Server]->Local IP address is: 192.168.1.103
05:06:37:5475:[Web Server]->Web Server started on port 8080
05:06:37:5647:[Startup]->Start automation engine...
05:06:37:5661:[Startup]->Initializing Speaker Client Interface
05:06:37:5794:[Speech]->Listening for remote speaker connections on port 10401
05:06:37:5833:[Database]->Opening (Mode=Read/Write) up HomeSeer Energy database /usr/local/HomeSeer/Data/Energy/Energy.hsd
05:06:37:6111:[Web Server]->Web Server authorized local login successful from: 192.168.1.100 User: homeseer
05:06:37:6257:[Warning]->File does not exist: /usr/local/HomeSeer/html/MQTT
05:06:37:7985:[Startup]->Updater services starting...
05:06:37:7992:[Startup]->Starting Find service...
05:06:37:8103:[Info]->Remote plug-in API interface started on port 10400
05:06:37:8105:[Startup]->Checking for available plug-ins
05:06:38:0882:[Plug-In]->Found plug-in: NetCAM, version: 3.0.0.14
05:06:38:3081:[Plug-In]->Found plug-in: mcsMQTT, version: 5.2.4.9
05:06:38:5271:[Plug-In]->Found plug-in: Harmony Hub, version: 4.0.11.0
05:06:38:7917:[Plug-In]->Found plug-in: Current Cost 3P, version: 0.0.0.42
05:06:39:1332:[Plug-In]->Found plug-in: SDJ-Health, version: 3.0.8.6
05:06:39:3556:[Plug-In]->Found plug-in: JowiHue, version: 4.0.1.0
05:06:39:5800:[Plug-In]->Found plug-in: Philips Hue, version: 4.0.16.0
05:06:39:8005:[Plug-In]->Found plug-in: Zigbee, version: 4.0.6.0
05:06:40:0227:[Plug-In]->Found plug-in: Pushover 3P, version: 0.0.0.48
05:06:40:2526:[Plug-In]->Found plug-in: Insteon, version: 3.0.7.26
05:06:40:4810:[Plug-In]->Found plug-in: Z-Wave, version: 3.0.2.0
05:06:40:6981:[Plug-In]->Found plug-in: drhsEventEnabler, version: 1.0.0.0
05:06:40:6988:[Startup]->Initializing Plug-Ins
Sub Main() Called
Connecting to server at 127.0.0.1...
05:06:40:9144:[Info]->Plugin Pushover 3P has connected. IP:127.0.0.1:47516
Connected, waiting to be initialized...
05:06:41:1032:[Starting Plug-In]->Initializing plugin Pushover 3P ...
[6/19/2020 5:06:41 PM] Plugin Starting - Checking if HS4/HS3...
05:06:41:1157:[Pushover 3P]->Plugin Starting - Checking if HS4/HS3...
[6/19/2020 5:06:41 PM] HS4 Detected ***** PLEASE NOTE HS4 IS NOT SUPPORTED *****
05:06:41:1175:[Pushover 3P]->HS4 Detected ***** PLEASE NOTE HS4 IS NOT SUPPORTED *****
[6/19/2020 5:06:41 PM] ****** InitIO Ended ******
05:06:41:1212:[Starting Plug-In]->Plugin Pushover 3P started successfully in 18 milliseconds
[6/19/2020 5:06:41 PM] BackGround Thread Started
05:06:41:1250:[Pushover 3P]->CreateTable Entered
[6/19/2020 5:06:41 PM] AddToTable : Plugin Started Row Count: 0
[6/19/2020 5:06:41 PM] RegisterWebPage Called: PushConfig - Configuration - Pushover 3P Configuration
05:06:41:1708:[Pushover 3P]->RegisterWebPage Called: PushConfig - Configuration - Pushover 3P Configuration
[6/19/2020 5:06:41 PM] User Key: uop8rrp4ygu4xw3gmq8ggfqte81u7a
[6/19/2020 5:06:41 PM] Emergency Expiry: 0
[6/19/2020 5:06:41 PM] Emergency Interval: 0
[6/19/2020 5:06:41 PM] Application Names/Tokens: HomeSeer=akny9bgwhvuinj6mu5m551noztfpjf
[6/19/2020 5:06:41 PM] Current Line 0 HomeSeer Current Line 1 akny9bgwhvuinj6mu5m551noztfpjf
[6/19/2020 5:06:41 PM] First Application Token (needed to download the sound files) akny9bgwhvuinj6mu5m551noztfpjf
[6/19/2020 5:06:41 PM] Attempting Sound Download....
05:06:41:1838:[Pushover 3P]->Attempting Sound Download....
[6/19/2020 5:06:41 PM] Downloading sounds from Pushover
05:06:41:1854:[Pushover 3P]->Downloading sounds from Pushover
05:06:41:2096:[Starting Plug-In]->Pushover 3P loaded in 500 milliseconds
05:06:41:2099:[Plug-In]->Finished initializing plug-in Pushover 3P
05:06:41:4521:[Info]->Plugin SDJ-Health has connected. IP:127.0.0.1:47522
05:06:41:5243:[Starting Plug-In]->Initializing plugin SDJ-Health ...
Starting initializiation.
[6/19/2020 5:06:41 PM] rSound Download <?xml version="1.0" encoding="UTF-8"?>
<response>
<sounds>
<pushover>Pushover (default)</pushover>
<bike>Bike</bike>
<bugle>Bugle</bugle>
<cashregister>Cash Register</cashregister>
<classical>Classical</classical>
<cosmic>Cosmic</cosmic>
<falling>Falling</falling>
<gamelan>Gamelan</gamelan>
<incoming>Incoming</incoming>
<intermission>Intermission</intermission>
<magic>Magic</magic>
<mechanical>Mechanical</mechanical>
<pianobar>Piano Bar</pianobar>
<siren>Siren</siren>
<spacealarm>Space Alarm</spacealarm>
<tugboat>Tug Boat</tugboat>
<alien>Alien Alarm (long)</alien>
<climb>Climb (long)</climb>
<persistent>Persistent (long)</persistent>
<echo>Pushover Echo (long)</echo>
<updown>Up Down (long)</updown>
<vibrate>Vibrate Only</vibrate>
<none>None (silent)</none>
</sounds>
<status>1</status>
<request>4ebc5609-4ea7-4da0-9c6f-c610ca824e0f</request>
</response>
[6/19/2020 5:06:41 PM] Adding 1 - pushover - Pushover (default)
[6/19/2020 5:06:41 PM] Adding 2 - bike - Bike
[6/19/2020 5:06:41 PM] Adding 3 - bugle - Bugle
[6/19/2020 5:06:41 PM] Adding 4 - cashregister - Cash Register
[6/19/2020 5:06:41 PM] Adding 5 - classical - Classical
[6/19/2020 5:06:41 PM] Adding 6 - cosmic - Cosmic
[6/19/2020 5:06:41 PM] Adding 7 - falling - Falling
[6/19/2020 5:06:41 PM] Adding 8 - gamelan - Gamelan
[6/19/2020 5:06:41 PM] Adding 9 - incoming - Incoming
[6/19/2020 5:06:41 PM] Adding 10 - intermission - Intermission
[6/19/2020 5:06:41 PM] Adding 11 - magic - Magic
[6/19/2020 5:06:41 PM] Adding 12 - mechanical - Mechanical
[6/19/2020 5:06:41 PM] Adding 13 - pianobar - Piano Bar
[6/19/2020 5:06:41 PM] Adding 14 - siren - Siren
[6/19/2020 5:06:41 PM] Adding 15 - spacealarm - Space Alarm
[6/19/2020 5:06:41 PM] Adding 16 - tugboat - Tug Boat
[6/19/2020 5:06:41 PM] Adding 17 - alien - Alien Alarm (long)
[6/19/2020 5:06:41 PM] Adding 18 - climb - Climb (long)
[6/19/2020 5:06:41 PM] Adding 19 - persistent - Persistent (long)
[6/19/2020 5:06:41 PM] Adding 20 - echo - Pushover Echo (long)
[6/19/2020 5:06:41 PM] Adding 21 - updown - Up Down (long)
[6/19/2020 5:06:41 PM] Adding 22 - vibrate - Vibrate Only
[6/19/2020 5:06:41 PM] Adding 23 - none - None (silent)
[6/19/2020 5:06:41 PM] AddToTable : Downloaded Pushover Sounds Row Count: 1
[6/19/2020 5:06:41 PM] Downloaded 23 sounds from Pushover - Adding Device Default
05:06:41:6232:[Pushover 3P]->Downloaded 23 sounds from Pushover - Adding Device Default
[6/19/2020 5:06:41 PM] Attempting To Produce a Client/Group List
05:06:41:6262:[Pushover 3P]->Attempting To Produce a Client/Group List
[6/19/2020 5:06:41 PM] Clients p20pro=removedp30pro=uop8rrp4ygu4xw3gmq8ggfqte81u7a
[6/19/2020 5:06:41 PM] Device Previously Removed - Don't Use
05:06:41:6276:[Pushover 3P]->Device Previously Removed - Don't Use
05:06:41:6282:[Pushover 3P]->Clients p30pro : uop8rrp4ygu4xw3gmq8ggfqte81u7a
[6/19/2020 5:06:41 PM] Current Line 0 p30pro Current Line 1: uop8rrp4ygu4xw3gmq8ggfqte81u7a
05:06:41:6329:[SDJ-Health]->HS Major Version = 4
05:06:41:6353:[SDJ-Health]->Version 3.0.8.6 Initialized.
Initializing done! Ready...
05:06:41:6370:[Starting Plug-In]->Plugin SDJ-Health started successfully in 112 milliseconds
05:06:41:7814:[Starting Plug-In]->SDJ-Health loaded in 567 milliseconds
05:06:41:7823:[Plug-In]->Finished initializing plug-in SDJ-Health
[6/19/2020 5:06:41 PM] Found Plugin Devices, Exit
[6/19/2020 5:06:41 PM] End Of Enumerator - Create Devices False
Plugin: Insteon Instance: starting...
[6/19/2020 5:06:42 PM] Devices Owned By Plugin 59 Name: Pushover 3P Root Device
[6/19/2020 5:06:42 PM] Devices Owned By Plugin 60 Name: Pushover 3P Enabled/Disabled
[6/19/2020 5:06:42 PM] Devices Owned By Plugin 61 Name: Pushover 3P Last Message Sent
[6/19/2020 5:06:42 PM] Devices Owned By Plugin 62 Name: Pushover 3P Disable Non-Emergency Messages
[6/19/2020 5:06:42 PM] Devices Owned By Plugin 63 Name: Pushover 3P Application Messages Remaining
05:06:42:1372:[Info]->Plugin Insteon has connected. IP:127.0.0.1:47526
[6/19/2020 5:06:42 PM] Array bCode(0) - 59
[6/19/2020 5:06:42 PM] Array bCode(1) - 60
[6/19/2020 5:06:42 PM] Array bCode(2) - 61
[6/19/2020 5:06:42 PM] Array bCode(3) - 62
[6/19/2020 5:06:42 PM] Array bCode(4) - 63
[6/19/2020 5:06:42 PM] Sending Status True Device Value: 100
05:06:42:1409:[Pushover 3P]->Sending Status True Device Value: 100
[6/19/2020 5:06:42 PM] Starting Flood Control Timer
05:06:42:1541:[Pushover 3P]->Starting Flood Control Timer
[6/19/2020 5:06:42 PM] Glance Message Delay Value 20
05:06:42:1569:[Pushover 3P]->Glance Message Delay Value 20
[6/19/2020 5:06:42 PM] Worker Thread Completed
05:06:42:2397:[Starting Plug-In]->Initializing plugin Insteon ...
05:06:42:3338:[Insteon]->Insteon Support library (Insteon.dll) version: 1.1.7.26
05:06:43:5587:[Insteon]->RF PLM contacted on /dev/ttyUSB0 with an Insteon address of 19.84.A0 and firmware version 99
05:06:44:6278:[Starting Plug-In]->Plugin Insteon started successfully in 2388 milliseconds
05:06:44:6280:[Insteon]->Waiting to initialize External Devices...
05:06:44:6378:[Starting Plug-In]->Insteon loaded in 2702 milliseconds
05:06:44:6380:[Plug-In]->Finished initializing plug-in Insteon
05:06:44:8275:[Info]->Plugin drhsEventEnabler has connected. IP:127.0.0.1:47530
05:06:44:8316:[Starting Plug-In]->Initializing plugin drhsEventEnabler ...
05:06:44:8352:[WARNING]->drhs_EventEnabler plugin may not function correctly on this version of HomeSeer (4.0.9.0) - Please update to at least version 3.0.0.143
05:06:44:8705:[Starting Plug-In]->Plugin drhsEventEnabler started successfully in 38 milliseconds
05:06:44:9454:[Starting Plug-In]->drhsEventEnabler loaded in 300 milliseconds
05:06:44:9458:[Plug-In]->Finished initializing plug-in drhsEventEnabler
05:06:45:1524:[Info]->Plugin Z-Wave has connected. IP:127.0.0.1:47534
05:06:45:2725:[Starting Plug-In]->Initializing plugin Z-Wave ...
05:06:45:2829:[Z-Wave]->InitIO called, plug-in version 3.0.2.0 is being initialized...
Z-Wave Plugin: OS Type is Linux
05:06:45:3840:[Z-Wave]->Database: Opening (Mode=Read Only) up HomeSeer database /usr/local/HomeSeer/Data/Z-Wave/Z-Wave2.db
05:06:45:4746:[Z-Wave]->Loading Z-Wave Network Objects...
05:06:45:4800:[Z-Wave]->1 total Z-Wave Network Objects loaded.
05:06:45:5639:[Z-Wave]->Loading Z-Wave Data Objects...
05:06:45:5658:[Z-Wave]->1 Networks were restored from the data in the database... Building data connections.
05:06:45:5665:[Z-Wave]->Network ECECBAE4 has 101 device data elements.
05:06:45:5725:[Z-Wave]->101 total Z-Wave Data Objects loaded.
05:06:45:9323:[Starting Plug-In]->Plugin Z-Wave started successfully in 659 milliseconds
05:06:45:9408:[Z-Wave]->0 event triggers were loaded from HomeSeer.
05:06:45:9441:[Z-Wave]->14 event actions were loaded from HomeSeer.
05:06:45:9561:[Starting Plug-In]->Z-Wave loaded in 1000 milliseconds
05:06:45:9563:[Plug-In]->Finished initializing plug-in Z-Wave
05:06:45:9653:[Z-Wave]->465 Simple AV Control Command Class Control Commands have been loaded successfully.
05:06:45:9718:[Z-Wave]->RaZberry: ============================================================ ==========
05:06:45:9729:[Z-Wave]->RaZberry: ----------------------------------------------------------------------
05:06:45:9745:[Z-Wave]->Initializing Z-Wave interface RaZberry (Ethernet Interface) at 192.168.1.101, port 4000
05:06:45:9754:[Z-Wave]->RaZberry: ----------------------------------------------------------------------
05:06:45:9784:[Z-Wave]->RaZberry: The Z-Wave Command Execution Thread was Started or Restarted.
05:06:45:9877:[Z-Wave]->RaZberry: Z-Wave Ethernet at IP 192.168.1.101, connected to interface ok.
Plugin: mcsMQTT Instance: starting...
05:06:46:1815:[Info]->Plugin mcsMQTT has connected. IP:127.0.0.1:47540
05:06:46:2398:[Z-Wave]->RaZberry: Processing data buffered by the interface while it was disconnected.
05:06:46:2424:[Z-Wave]->RaZberry: The Z-Wave API Execution Thread was Started or Restarted.
05:06:46:2499:[Z-Wave]->RaZberry: Getting node information from controller...
05:06:46:3347:[Starting Plug-In]->Initializing plugin mcsMQTT ...
05:06:46:3530:[mcsMQTT]->Version 5.2.4.9 Registered with Homeseer
05:06:46:6181:[Starting Plug-In]->Plugin mcsMQTT started successfully in 283 milliseconds
05:06:46:6643:[Starting Plug-In]->mcsMQTT loaded in 700 milliseconds
05:06:46:6646:[Plug-In]->Finished initializing plug-in mcsMQTT
05:06:46:6703:[HSTouch Server]->Server started on port 10200
05:06:46:8590:[Startup]->HStouch server started, waiting for clients to connect.
05:06:46:8611:[Startup]->Running the startup script Startup.vb
05:06:47:0663:[Insteon]->External Device Registration complete.
05:06:47:7283:[Startup]->Starting Event Scheduler...
05:06:47:7296:[Startup]->HSSentry is disabled in Setup, sentry will not be started.
05:06:47:7309:[Info]->Checking device parent child relationships...
05:06:47:7355:[Startup]->Scripting is OK and is now running Startup.vb
05:06:47:7373:[Info]->No device issues found
05:06:47:7374:[Startup]->Start up complete.
Type 'shutdown' to shutdown HomeSeer
> 05:06:47:7442:[TTS]->Speak ():Welcome to Home-Seer
ALSA lib pcm_dmix.c:1108:(snd_pcm_dmix_open) unable to open slave
audio_open_alsa: failed to open audio device default. No such file or directory
05:06:47:7836:[TTS]->Speak ():Web server port number is 8080
05:06:47:8342:[Info]->System connected to MyHS Service, waiting for acknowledge...
File upload thread started
05:06:47:8978:[Info]->System connected to MyHS Service successfully with license ID 663928.
05:06:48:1576:[Event]->Event Trigger "Scripts Solar Position - Daytime"
05:06:48:1598:[Event]->Running script in background: SolarPosition.vb
05:06:48:8738:[mcsMQTT]->MQTTClient is Connected to broker at 192.168.1.101
Error: RaZberry: The RaZberry interface did not respond to the request for the controller capabilities - it may be disconnected or malfunctioning (3).
05:06:51:2981:[Z-Wave Error]->RaZberry: The RaZberry interface did not respond to the request for the controller capabilities - it may be disconnected or malfunctioning (3).
05:06:51:3173:[Z-Wave Warning]->Trying to re-connect to Ethernet interface at IP 192.168.1.101...
05:06:51:9602:[SDJ-Health]->PEData read successfully from child device #246
05:06:51:9741:[SDJ-Health]->PEData read successfully from child device #247
05:06:51:9817:[SDJ-Health]->PEData read successfully from child device #248
05:06:51:9938:[SDJ-Health]->PEData read successfully from child device #249
05:06:52:0026:[SDJ-Health]->PEData read successfully from child device #250
05:06:52:0100:[SDJ-Health]->PEData read successfully from child device #415
05:06:52:0192:[SDJ-Health]->PEData read successfully from child device #416
05:06:52:0294:[SDJ-Health]->PEData read successfully from child device #417
05:06:52:0377:[SDJ-Health]->PEData read successfully from child device #418
05:06:52:0451:[SDJ-Health]->PEData read successfully from child device #419
05:06:52:0554:[SDJ-Health]->PEData read successfully from child device #420
05:06:52:0653:[SDJ-Health]->PEData read successfully from child device #421
05:06:52:0727:[SDJ-Health]->PEData read successfully from child device #422
05:06:52:2551:[SDJ-Health]->Found existing battery database.
Can't find custom attr constructor image: /usr/local/HomeSeer/Scheduler.dll mtoken: 0x0a0000c0 due to: Could not load file or assembly 'Newtonsoft.Json, Version=12.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies.
05:06:52:3013:[SDJ-Health]->Polling devices started.
05:06:52:3043:[SDJ-Health]->Activity Checking stopped.
05:06:52:5717:[SDJ-Health]->Read Exclusion List from INI adding 0 devices.
05:06:52:5783:[SDJ-Health]->GeneralHealthTimer turned off as no interfaces set to be checked.
05:06:53:0922:[Z-Wave]->*********************************************************** ********************
05:06:53:0929:[Z-Wave]-> STARTUP COMPLETE: All configured interfaces were successfully initialized.
05:06:53:0935:[Z-Wave]->*********************************************************** ********************
05:06:56:3212:[Z-Wave]->RaZberry: Z-Wave Ethernet at IP 192.168.1.101, connected to interface ok.
05:06:56:5741:[Z-Wave]->RaZberry: Getting node information from controller...
05:06:58:7196:[Z-Wave]->RaZberry: Controller Manufacturer: Telsey, ID=0x2, Type=0x4
05:06:58:7205:[Z-Wave]->RaZberry: Controller firmware version: 5.4
05:06:59:1572:[Z-Wave]->RaZberry: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
05:06:59:1580:[Z-Wave]->RaZberry: Z-Wave Serial API version: 5
05:06:59:1587:[Z-Wave]->RaZberry: Z-Wave interface node ID: 1, Home ID: ECECBAE4
05:06:59:1597:[Z-Wave]->RaZberry: Found 21 Z-Wave nodes in interface node ID 1 (RaZberry)
05:06:59:1962:[Z-Wave]->The interface's security support has been set.
05:06:59:2230:[Z-Wave]->RaZberry Controller chip type is ZW050x.
05:06:59:2238:[Z-Wave]->RaZberry Controller is static lib.
05:06:59:2246:[Z-Wave]->RaZberry There is a SUC/SIS in the network.
05:06:59:2253:[Z-Wave]->RaZberry is the SIS for the network.
05:06:59:2279:[Z-Wave]->RaZberry: ............................................................ ..........
05:06:59:2286:[Z-Wave]->RaZberry: .............................. FINISHED ..............................
05:06:59:2293:[Z-Wave]->RaZberry: ............................................................ ..........
05:07:02:3468:[SDJ-Health]->Z-Wave Device #175 polled succesfully.
05:07:02:3478:[SDJ-Health]->Polled Device #174 added to message queue for processing.
05:07:16:0692:[Z-Wave]->Starting Z-Wave Polling for Network ECECBAE4...
shutdown
05:07:26:2129:[Shutdown]->Application shutdown at 6/19/2020 5:07:26 PM
05:07:26:2406:[Shutdown]->Running shutdown script ...
05:07:26:2408:[Shutdown]->Shutdown Script Completed
05:07:26:2409:[Shutdown]->Shutting down plug-ins ...
05:07:26:2414:[Shutdown]->Shutting down all plug-ins.
05:07:26:2415:[Shutdown]->Shutting down plug-in: drhsEventEnabler
05:07:26:2434:[Shutdown]->Shutting down plug-in: Insteon
05:07:26:2630:[1]->Error while shutting down Plugin : The type initializer for 'System.Windows.Forms.XplatUI' threw an exception.
05:07:26:2633:[Shutdown]->Shutting down plug-in: mcsMQTT
ShutdownIO
Shutting down plugin
Disconnected from server - client
05:07:26:2726:[Info]->Plugin drhsEventEnabler with ID: and Instance: has disconnected
Writing events, serializing start...
Writing events, done serializing, elapsed MS: 18
05:07:27:1186:[Shutdown]->Shutting down plug-in: Pushover 3P
[6/19/2020 5:07:27 PM] ShutdownIO Called
05:07:27:1220:[Shutdown]->Shutting down plug-in: SDJ-Health
ShutdownIO complete.
05:07:27:1259:[Shutdown]->Shutting down plug-in: Z-Wave
05:07:27:1280:[Error]->Posting back to plugin web page MQTT: Object reference not set to an instance of an object->
Server stack trace:
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x0014d] in <f2b3ab7dfff746f594d2ef5b16ec3c90>:0
at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr)
at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int )
at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00040] in <cc78980d80864114adfa9f72caadc35e>:0
05:07:27:1397:[Info]->Plugin SDJ-Health with ID: and Instance: has disconnected
Disconnected from server - client05:07:27:1445:[Info]->Plugin Pushover 3P with ID: and Instance: has disconnected
05:07:27:5910:[Error]->Posting back to plugin web page MQTT: Object reference not set to an instance of an object->
Server stack trace:
05:07:28:0720:[Shutdown]->Finished shutting down all plug-ins.
05:07:28:0722:[Shutdown]->Shutting down plug-in Comms ...
Connection lost, exiting
05:07:28:0803:[Shutdown]->Saving Data ...Connection lost, exiting
05:07:28:0981:[Info]->Plugin Insteon with ID: and Instance: has disconnected
05:07:28:0984:[Info]->Plugin mcsMQTT with ID: and Instance: has disconnected
05:07:28:0984:[Info]->Plugin Z-Wave with ID: and Instance: has disconnected
05:07:29:9027:[Shutdown]->Shutting down email ...
05:07:29:9030:[Shutdown]->-------------------------------------------------------------------
05:07:29:9033:[Shutdown]-> HomeSeer Successfully Shut Down Now
05:07:29:9036:[Shutdown]->-------------------------------------------------------------------
HomeSeer Linux has shut down.
root@Debian10:/usr/local/HomeSeer# while (ps -ef | grep HSPI_Insteon.exe | grep -v grep) do sleep 5; done
root 10414 1 4 17:06 pts/0 00:00:02 /usr/bin/mono /usr/local/HomeSeer/HSPI_Insteon.exe
root 10414 1 3 17:06 pts/0 00:00:02 /usr/bin/mono /usr/local/HomeSeer/HSPI_Insteon.exe
root 10414 1 2 17:06 pts/0 00:00:02 /usr/bin/mono /usr/local/HomeSeer/HSPI_Insteon.exe
