Dimmer Module - Light on and ramp rate
    Hey Mark,
    I have some new Plug-in Modules and can't get the Light on and ramp rate to work on them, works fine on the older. I see an issue in the log too.
    FW 4.2 2419
    Jun-26 17:57:08 Insteon Process ACK Message for device Family Room Side Lamp (54.E0.D4)
    Jun-26 17:57:08 Insteon Setting status and value for device 54.E0.D4:1. Old status:0 Old Value:0, New Status:2 New Value:100
    Jun-26 17:57:08 Insteon ProcessInsteonTrigger Parameters: DeviceID=54.E0.D4, Command=2E, Command2=FF, Group=1
    Jun-26 17:57:08 Insteon Received a Direct ACK from Family Room Side Lamp (54.E0.D4): 54 E0 D4 2B 90 F6 27 2E FF
    Jun-26 17:57:08 Insteon Received STX 0x50 (Raw Insteon Rec):54 E0 D4 2B 90 F6 27 2E FF
    Jun-26 17:57:07 Insteon ..Got RF PLM Response 02 62 54 E0 D4 0F 2E FF 06
    Jun-26 17:57:07 Insteon Sending command 02 62 54 E0 D4 0F 2E FF to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    Jun-26 17:57:07 Insteon Trouble converting [] to integer
    Jun-26 17:57:07 Event Event Trigger "Family Room test - Copy"
    Jun-26 17:57:07 Event Event Family Room test - Copy triggered by the event page 'Run' button.
    Quick update, did a reboot and the integer error went away, but still not working properly.
      did they register properly with the plugin? if so what is the devicetype from the [device x] section of the device.
      does the device have links back to homeseer?
      Mark
      HS3 Pro 3.0.0.534
        They register fine from what I see, and I can control them in Homeseer no problem, it's just the light on with ramp rate event that isn't working. The device status changes, but the light is still off (and LED stays red on module)
        Device Type: Dual-Band LampLinc
        Here's the link table:
        Link #2 Outlet has local control reporting to HomeSeer
        Link #5 Outlet is controlled by Family Room Lights (30.CE.B3) - On Level: 100%, Ramp Rate: 2 Sec.
        Link #1 Outlet is controlled by HomeSeer using RF PLM Group #0 (i2CS Registration Link) - On Level: 100%, Ramp Rate: .5 Sec.
        Link #3 Outlet is controlled by HomeSeer using RF PLM Group #254 (HomeSeer All Devices Group) - On Level: 100%, Ramp Rate: .1 Sec.
        Link #4 Outlet is controlled by HomeSeer using RF PLM Group #43 Registered Group #8 'Family Room Scene All Lights' - On Level: 100%, Ramp Rate: .1 Sec.
          can you post the [device] section from the insteon.ini for the device
          i may need to revise that action based on the info in the insteon.ini
          Mark
          HS3 Pro 3.0.0.534
            [Device 69]
            DatabaseDelta=5
            DeviceID=54.E0.D4
            DeviceLocation=Family Room
            DeviceName=Side Lamp
            DeviceType=010E
            EEValues=LEDBrightness=0,DefaultOnLevel=254,DefaultRampRate= 28,OpFlags1=96
            FailedInteractions=30
            FirmwareVer=43
            HopData=373,12,351,10
            LastContact=6/26/2020 5:46:02 PM
            Link 1=A2 00 2B 90 F6 FF 1C 00 1
            Link 2=E2 01 2B 90 F6 00 00 01 2
            Link 3=A2 FE 2B 90 F6 FF 1F 01 3
            Link 4=A2 2B 2B 90 F6 FF 1F 01 4
            Link 5=A2 01 30 CE B3 FF 00 01 5
            LinksDownloaded=1
            NumLinks=5
            PollingInterval=0
            Protocol=3
            RecentDatabaseDelta=5
            TotalInteractions=360
              can you try the send device command action to your device with the following values: 34 FF
              Mark
              HS3 Pro 3.0.0.534
                Light turned on immediately
                Jun-28 13:04:00 Insteon Setting status and value for device 54.E0.D4:1. Old status:0 Old Value:0, New Status:2 New Value:100
                Jun-28 13:04:00 Insteon Process ACK Message for device Family Room Side Lamp (54.E0.D4)
                Jun-28 13:04:00 Insteon ProcessInsteonTrigger Parameters: DeviceID=54.E0.D4, Command=34, Command2=FF, Group=1
                Jun-28 13:04:00 Insteon Received a Direct ACK from Family Room Side Lamp (54.E0.D4): 54 E0 D4 2B 90 F6 27 34 FF
                Jun-28 13:04:00 Insteon Received STX 0x50 (Raw Insteon Rec):54 E0 D4 2B 90 F6 27 34 FF
                Jun-28 13:04:00 Insteon ..Got RF PLM Response 02 62 54 E0 D4 0F 34 FF 06
                Jun-28 13:04:00 Insteon Sending command 02 62 54 E0 D4 0F 34 FF to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  I guess insteon made a changed to the firmware at ver 43. I had it in my records the change didn't occur until fw 44.
                  I'll fix this in the next beta
                  Mark
                  HS3 Pro 3.0.0.534
                    sounds good, thanks for looking into it. Let me know when its ready to test. As always, appreciate the level of support.
                      Hey Mark, any timeline for this fix? Thx so much
                        i'll post something in the next day or two. was just waiting to see if anything else popped up
                        Mark
                        HS3 Pro 3.0.0.534
                          i posted 3.0.7.29. let me know how it goes.
                          Mark
                          HS3 Pro 3.0.0.534
                            Looks to be working perfectly!
                              thanks for reporting back. I wonder if i broke this functionality for someelse's device with a different fw requirement. i guess i'll see.
                              Mark
                              HS3 Pro 3.0.0.534
