HS4 mnsandler Insteon plugin development chronicals
    #16
    I have Insteon 2342-222 Mini Remote 8-Scene Keypad and need help programming them. I see linking to individual modules but I want to link to events, is that possible?
      #17
      you can use the "insteon special triggers" in an event. these are triggers the fire when you press a button.
      Mark
      HS3 Pro 4.2.19.5
        #18
        Working on the triggers for the HS4 plugin.
Name:	hs4 triggers.PNG
        Mark
        HS3 Pro 4.2.19.5
          #19
          making more progress on the Triggers and Events
Name:	HS4 Trigger and Event.PNG
          Mark
          HS3 Pro 4.2.19.5
            #20
            I have a full set of working insteon triggers and actions.
            Mark
            HS3 Pro 4.2.19.5
              #21
              Finished the code to convert HS3 Actions to the new HS4 format. On to the Trigger conversion code...
              Mark
              HS3 Pro 4.2.19.5
                #22
                Finished the code to convert HS3 Triggers to the new HS4 format. Boy, i thought that would be easier based on lessons learned from the Actions.
                Mark
                HS3 Pro 4.2.19.5
                  #23
                  ok. I revised my device creation code to support the migration of hs3 devices to the new HS4 classes. Onto the Groups...
                  Mark
                  HS3 Pro 4.2.19.5
                    #24
                    I have do some more testing on Migrating Groups, but I got a little side tracked and worked on "registering devices". I need to make some decisions about the UI in general.
                    Mark
                    HS3 Pro 4.2.19.5
                      #25
                      Worked on updating and deleting devices from the HS device page.
                      Mark
                      HS3 Pro 4.2.19.5
                        #26
                        Started working on adding the customer Insteon Settings to the hs device page. This is where I'm having the UI struggle. The Insteon tab only allows for simple settings. I can't add the previous buttons for reprogramming the device, etc.
                        Mark
                        HS3 Pro 4.2.19.5
                          #27
                          I temporarily stopped the device settings UI. I may have to fold the settings into custom html pages so everything device related is in one place. I dont want to support settings in two places unless i get reuse the exact same set of code which never seems to be the situation here.
                          So, i decided to work on something easier (managing groups) until i get a feel for the new hs4 ui specs
                          Mark
                          HS3 Pro 4.2.19.5
                            #28
                            I spent a few days this weekend working on the new UI associated with providing status messages while registering a new device. I think I have a working model i can use for other routines like adding links, reprogramming devices, etc.
                            Mark
                            HS3 Pro 4.2.19.5
                              #29
                              Worked on the Manage Device page this past weekend. got the location filter working to change the listed devices.
                              Mark
                              HS3 Pro 4.2.19.5
                                #30
                                latest progress
                                manage devices page: these buttons all work
                                manage interface: all finished
                                Edit device: in progress; need to added 'link editing'
Name:	example device page.png
                                Mark
                                HS3 Pro 4.2.19.5
