I was having some trouble with a couple of linked switches so went into the insteon plugin to reprogram them with the Reprogram Device button & never get the Continue Button. It just seems to hang. But watching the log shows "The Insteon device was successfully reprogrammed." I am also seeing an error in the log "Trouble converting [] to integer". Ran on several devices with the same results. Running HS 4.1.0.0.
Reprogram Device
The UI issue is just an incompatibility between the v3 plugin and HS4.
regarding "Trouble converting [] to integer", can you enable detailed logging within the plugin and capture the same error and post a log snippetMark
HS3 Pro 3.0.0.534
can you post the list of links from the from the Insteon Laundry Room - Door Switch (48.75.10) device. i can't tell if they have all been read correctlyMark
HS3 Pro 3.0.0.534
Link #1 Load controls Insteon Laundry Room - Office Switch (2) Load (48.55.1A)
Link #4 Load has local control reporting to HomeSeer
Link #5 Load is controlled by Insteon Laundry Room - Office Switch (2) (48.55.1A) - On Level : On
Link #2 Load is controlled by HomeSeer using RF PLM Group #0 (i2CS Registration Link) - On Level : Off
Link #3 Load is controlled by HomeSeer using RF PLM Group #24 Registered Group #14 'Insteon All Lights' - On Level : On
Link #6 Load is controlled by HomeSeer using RF PLM Group #254 (HomeSeer All Devices Group) - On Level : On
are you still having troubles with the linked switches you originally mentioned?Mark
HS3 Pro 3.0.0.534
have you tried a factory reset on device and then used the reprogram device function to recreate the links?Mark
HS3 Pro 3.0.0.534
Very strange. can you post the [device x] section from the insteon.ini for the device you just reset and reprogrammedMark
HS3 Pro 3.0.0.534
that all looks fine. if you aren't seeing any other side affects, lets not worry about the error right now.
i dont plan to spend time modifying the hs3 plugin for hs4. I'm working on a new hs4 plugin.
there are a few other hs4 issues reported that i just can't fix at this point.
despite what hst says, hs3 plugins aren't 100% compatible with hs4.Mark
HS3 Pro 3.0.0.534
