I have an I/O Linc whose sense abilities died after a lightning storm. I've received a replacement but the Replace procedure will not run. I get the following error:
Program And Replace Device: System.ArgumentOutOfRangeException: Index and length must refer to a location within the string. Parameter name: length at System.String.Substring(Int32 startIndex, Int32 length) at Insteon.Support.Core.InsteonModule.ProgramAndReplaceDevice(S tring SrcID, String DestID)
Before ordering a replacement I did a factory reset on the old device, and then a reprogram via the plugin. That seemed to work fine but the sense ability did not return. Now the Replace won't run.
I just noticed the Firmware Version field for the old device is blank. Perhaps the Reprogram procedure didn't work 100% because the device is bad, and perhaps the Replace procedure needs that info?
Please help.
Please help.
