Database Empty in config
    Was working great. Rebooted the HS4 computer and the devices under config is blank. All the devices in HS4 are still there. Also the Insteon remote on iOS still works also. What button can I click to update the config devices?
    what version of the plugin are you running?
    sounds like the insteon.ini got cleared. shutdown hs, restore the insteon.ini from one of the recent backups in the config folder, and restart
    Mark
    HS3 Pro 3.0.0.534
      Restoring the ini worked. Thank you for your help
        Glad you got it working. can you tell me what version of the plugin you are running?
        Mark
        HS3 Pro 3.0.0.534
          Sorry I forgot to send the version
          3.0.7.20
            thanks. there should be an insteon Plugin device in the hs devices with a copy of the insteon.ini txt on the Insteon tab
            Mark
            HS3 Pro 3.0.0.534
              Did you want me to do something?
                no, just wanted to make you aware of another source of the insteon.ini contents. I assume it looks ok
                Mark
                HS3 Pro 3.0.0.534
                  Yes it appears it's all good. Hs4 lost all the plug-in registrations too for all the plug-in and setup too. So I doubt it's your plug-in problem. This was happening with the Alexa part of the the HS servers was messed up. I rebooted to see if that fixed the problem.
