Using the Stop Ramp from a dimmer in and HS event.
    I have a few insteon dimmers with blow live load triacs so I'm using them to control RBGWW LED strips on a Z-Wave controller. The ON and OFF events work just fine but I can't find a way to set the dimming level using and HS3 event. I see the following in the log:
    Jul-25 1:23:37 PM Insteon Received Kitchen Kitchen - Over Cabinet Lights (18.2E.9F) Stop Ramp
    Jul-25 1:23:35 PM Insteon Received Kitchen Kitchen - Over Cabinet Lights (18.2E.9F) Start Ramp
    but there doesn't seem to be a "Stop Ramp" value I can trigger on so that I can read and set the dimmer value...
    any ideas?
    try the insteon action lights on at ramp rate
    Mark
    HS3 Pro 3.0.0.534
      I know this isn't what you're asking, but the Insteon dimmer Triacs are easily replaceable if you have a soldering iron. I forget the part number, but its readable on the triac and readily available at DigiKey or Mouser. I've done a couple that were taken out by a faulty dimmable CFL bulb.
        Hi, thank you I think I still have one that was removed and isn't installed somewhere else yet which I will try out. The others are already installed and are perfect for controlling the RGBW dimmers (Qubino).
          Thanks Mark, but forgive me for asking this ... but where is this? Under the "Plugins | Insteon | Configuration", under Events or somewhere else?
          I tried creating an event but I can't figure out how to read the dimming value setting to set the RGBW controller:
Name:	Annotation 2020-07-26 082719.jpg
            I guess i didn't understand what you were trying to do.
            you will need to write a script command using hs.setdevicevaluebyref to set your rgbw device value to a value of another device. i dont think that functionality exists as native event action
            Mark
            HS3 Pro 3.0.0.534
              That's what I thought Thank you
                Coming back to this thread and sort of related; I just got a KeypadLinc that works but the main load buttons won't dim ... the load is either on or off using the physical buttons and setting the dim value does nothing (unless it is 100%). Any known fix for this? I can't return the item (bought on cheatBay).
                  did you try a factory reset on the device?
                  Mark
                  HS3 Pro 3.0.0.534
                    yes I now have two improperly working KeypadLincs The original one has intermittent comms and this one that won't dim.
                      what is the fw ver of the "new" one?
                      Mark
                      HS3 Pro 3.0.0.534
                        Are you sure you have the dimmable version? Keypadlincs are sold with Triacs (dimmable), and relays (not dimmable).
                          I didn't know that! However, I just confirmed it is supposed to be a dimmable version:
Name:	2020-07-28 10.59.08s.jpg
                            Hi Mark,
                            Firmware:45 (HW Rev 8.8 0219)
                            Here is the log from the tap add:
                            Jul-28 12:07:35 PM Insteon Edit Insteon Device #25 Addr: 52.2B.E6, Name:Tap-Added Dual-Band KeypadLinc Dimmer 0, Location:Unknown
                            Jul-28 12:07:23 PM Insteon Tap-add mode added a new Insteon device, #25 at Address 52.2B.E6(Dual-Band KeypadLinc Dimmer)
                            Jul-28 12:07:22 PM Insteon Attempting to update the status for Unknown Tap-Added Dual-Band KeypadLinc Dimmer 0 (52.2B.E6)
                            Jul-28 12:07:21 PM Insteon Found unused link #21 in our address space, assigning for use.
                            Jul-28 12:07:21 PM Insteon Found unused link #20 in our address space, assigning for use.
                            Jul-28 12:07:21 PM Insteon Found unused link #19 in our address space, assigning for use.
                            Jul-28 12:07:21 PM Insteon Found unused link #14 in our address space, assigning for use.
                            Jul-28 12:07:21 PM Insteon Found unused link #13 in our address space, assigning for use.
                            Jul-28 12:07:21 PM Insteon Reloading 25 Insteon device information tables...
                            Jul-28 12:07:21 PM Insteon Reloading 5 Insteon group information tables...
                            Jul-28 12:07:21 PM Insteon ..finished saving comm stats.
                            Jul-28 12:07:21 PM Insteon Saving comm stats...
                            Jul-28 12:07:21 PM Insteon Calling AddRecord for 52.2B.E6 254 False
                            Jul-28 12:07:21 PM Insteon Calling AddRecord for 52.2B.E6 6 True
                            Jul-28 12:07:20 PM Insteon Calling AddRecord for 52.2B.E6 5 True
                            Jul-28 12:07:20 PM Insteon Calling AddRecord for 52.2B.E6 4 True
                            Jul-28 12:07:20 PM Insteon Calling AddRecord for 52.2B.E6 3 True
                            Jul-28 12:07:19 PM Insteon Calling AddRecord for 52.2B.E6 1 True
                            Jul-28 12:07:19 PM Insteon Got Op Flags response from Insteon ID 52.2B.E6, Op Flags 05=0D
                            Jul-28 12:07:19 PM Insteon Got Op Flags response from Insteon ID 52.2B.E6, Op Flags 00=00
                            Jul-28 12:07:12 PM Insteon Calling AddRecord for 52.2B.E6 1 True
                            Jul-28 12:07:12 PM Insteon Attempting to add Device 52.2B.E6
                            Jul-28 12:07:12 PM Insteon Set tap add job data: Name:Tap-Added Dual-Band KeypadLinc Dimmer 0 Type:0142 Firmware:45
                            Jul-28 12:07:12 PM Insteon Considering link complete as a tap-add request from device 52.2B.E6 (Dual-Band KeypadLinc Dimmer)
                              what is the default on level for the dimmer? have you tried setting it to 80% and see if the physical switch will respond accordingly
                              Mark
                              HS3 Pro 3.0.0.534
